Oil change for the first time
Old Nov 3, 2007 | 08:47 AM
RamQuadHD's Avatar
RamQuadHD
Default Oil change for the first time
Hey guys, I'm about to change the oil myself for the first time on this truck. Is there anything that I should know first orsome special steps? I tried finding a thread here but no luck. 2006 CTD dually. Thanx.
Old Nov 3, 2007 | 09:17 AM
cujo's Avatar
cujo
Default RE: Oil change for the first time
ORIGINAL: RamQuadHD
https://dodgeforum.com/m_725240/tm.htm
This thread is kind of buried.
Old Nov 3, 2007 | 09:19 AM
Tommygunz's Avatar
Tommygunz
Biggest deal is the filter is rediculously tight on a brand new motor, and don't forget to pre-fill the filter before installation
Old Nov 3, 2007 | 09:24 AM
cujo's Avatar
cujo
Another gotcha I've seen posted is make sure the oil filter gasket from the old filter comes off with the filter and doesn't stay stuck to the housing. That will make a nice mess if you miss that.
Old Nov 3, 2007 | 09:29 AM
Tommygunz's Avatar
Tommygunz
Good call...
Old Nov 3, 2007 | 09:50 AM
RamQuadHD's Avatar
RamQuadHD
Very helpful. I thought I saw this thread before but couldn't find it. Thank you!
Old Nov 3, 2007 | 10:06 AM
UpBranchLiner's Avatar
UpBranchLiner
ORIGINAL: Tommygunz
You aint kiddin.
Old Nov 3, 2007 | 01:07 PM
JimmyDiablo's Avatar
JimmyDiablo
and have a nice drain bucket capable of 3 gallons.
Old Nov 3, 2007 | 01:57 PM
DiEseLjunKy's Avatar
DiEseLjunKy
They clear coat the new oil filters on there from the factory which is why they're such a pain. You'll never have as much fun getting the filter off as you do that very first time I don't know what they're called but you can get them at any autoparts store real cheapit's a stamped metal cup shaped tool that slips over the bottom of the filter and you put a 3/8's drive extension in it hooked to your ratchet and just ratchet the filter off. Nothing I tried would bust the filter loose that first time until I got one of those. You can forget those wrap around filter tools.They're worthless for these trucks there's no way to get your hands in there.
Old Nov 3, 2007 | 03:52 PM
FroneDaddy's Avatar
FroneDaddy
ORIGINAL: DiEseLjunKy
That's what I use and have had no problems
