Cab Lights!!!
#41
ORIGINAL: tdmopar59
![](http://www.guildscc.org/g2468/Man%20with%20Megaphone.gif)
i said WHEN ARE YOU GETTING YOURS!![Big Grin](https://dodgeforum.com/forum/images/smilies/biggrin.gif)
![Frown](https://dodgeforum.com/forum/images/smilies/frown.gif)
#42
#43
Yeah definitely wat to be gentle drilling otherwise the hail damage look will happen aroung the hole were drilling (yes the cab light will probably cover it... but will it seal properly if the roof isn't flat anymore?.. just something to think about.)
__________________________________________________ __
Here is a couple pics of mine, I don't think there is any chance for leaking. It stormed the day after I got mine on, and I didn't see any thing come in at all. Basicall the cab light is sealed and water cannot enter it. There are two holes through the cab light for the screws and one hole in the middle where the wire come out. You have to drill 3 holes (2 screws and one for the wire). The bottom of the cab light is covered with a foam rubber stuff, whichshouldbe enough of a seal by itself, but on top of that the supply rubber washers for the screws. I applied silicone to the threads of the screws. I also applied silicone to the very small hole where the wires go in to plug it up (just incase the water was to get throught the foam rubber on the bottom of the cab light. Not sure there is any chance for a leak really, I think all the points were adequately covered.
![](http://usera.imagecave.com/savagebasher/IMG_3149.JPG)
![](http://usera.imagecave.com/savagebasher/IMG_3148.JPG)
![](http://usera.imagecave.com/savagebasher/IMG_3153.JPG)
![](http://usera.imagecave.com/savagebasher/IMG_3155.JPG)
![](http://usera.imagecave.com/savagebasher/IMG_3156.JPG)
![](http://usera.imagecave.com/savagebasher/IMG_3157.JPG)
![](http://usera.imagecave.com/savagebasher/IMG_3161.JPG)
![](http://usera.imagecave.com/savagebasher/IMG_3170.jpg)
Has anyone put cab lights on their truck and then had problems with them leaking?
#47
^^^ hehehe...
I basically used your, but you had
.....instead I used 5-3/8 , 17 , 26 , 35 , 46-5/8, so that way the space between my lights would measure 11-5/8 , 9 , 9 , 11 5/8. the space between your lights (using your measurements) is 12-3/8 , 8-1/4 , 9 , 11-5/8.
Measure the top side at 5-3/8 - 17-3/4 - 26 - 35 - 46-5/8
