Exhaust system advice
Old Nov 28, 2007 | 01:07 PM
  #31
chouseal's Avatar
chouseal
Default RE: Exhaust system advice
All right, gents... let us know how it goes.
Hey, try it in that big cropduster of yours, too. I'd do one engine at a time, though, just to be safe. Or maybe one per side? Since you'll be upping the output levels due to the polishing action, if you were to just do one or both on the left side, for example—crazy!—it'd probably pull to the right pretty hard. Adjust flight plans accordingly.
Old Nov 28, 2007 | 01:12 PM
  #32
Tommygunz's Avatar
Tommygunz
I have also heard alot about water/alcohol injection, Could it be possible to hook your truck up to a bottle of jim beam and let her rip? Somebody has got to try that!!!!
Old Nov 28, 2007 | 10:11 PM
  #33
Aero Ram's Avatar
Aero Ram
ORIGINAL: chouseal
That Cropduster gets ALOT of sand through its intake and takes it very well...lol
FYI I modded my crop duster witha 105mm, 40mm and a 30mm chain gun
And maybe shot a deer or 2 while on the range but who knows
Tommy that jim beam will work fine give it a couple a shots worth
Old Nov 28, 2007 | 11:18 PM
  #34
energinerbuzzy's Avatar
energinerbuzzy
The alchohol content in Jim Beam is way to high and as such will evaporate before it makes it to the thru the turbo. We use Shiner Bock down in these parts, it's only 5% and has fine lubricity qualities. I have been using the "Water Bong" method here lately and it works great.
It prety simple to set up. Go to home depot and buy a 6x 8 foot sheet of heavy gage plastic. Then go to you nearest Marine parts store and but a 500 GPH Bilge pump. Line the bed of your truck with the plastic and mount the pump near the cab, in the bottom of the bed.
Run the hose from the pump thru a 1" hole drilled thru the bed. Find the best routing to get to the exhaust manifold and drill a 9/16" hole and tap between each cylinder. Use a 3 wayT spitter that can be found at home depot also and install nipples into the manifold. Run the 3 lines off the splitter to the manifold nipples and your done. Now you just need to install the togle switch on the dash and your good to go.
Your bed will hold aprox. 500 gallons on water, with the 500 gallon per hour pump you'll be able to run wide open at 3000 rpm's with 700 hp for an hour straight. EGT's will never get over 250 f and you'll have plenty of back pressure. And talk about smoke??? Who needs it with all the steam you'll be putting out. You will be capable of creating your own weather system in the right conditions!
This has to be the lamest post ever!! [sm=lame.gif]
Old Nov 29, 2007 | 11:32 AM
  #35
BuckieD's Avatar
BuckieD
The ceramic bearings can't take the extreme torque of these motors. I had a buddy try them and they broke apart, sending the titanium race flying into the Flux Capacitator and completely destroyed the Warp Drive!!
atleast it didn't hurt your discombobulator!
Old Nov 29, 2007 | 11:42 AM
  #36
chouseal's Avatar
chouseal
Aw, shucks... but it was fun!
Old Dec 1, 2007 | 06:01 AM
  #37
Aero Ram's Avatar
Aero Ram
Well buzzy you've always been lame...what can I say...
