Clutch prob when brakes applied
Old Nov 27, 2007 | 02:33 PM
ahote's Avatar
ahote
Default Clutch prob when brakes applied
I have an 02 3500 6 speed with 110,000 miles. When I start motor and don't apply the brakes the gears shift easy, but when I apply brake I can no longer shift into any gear. I have considered replacing master clutch and slave cylinders, but i'm not sur that these are the problems. Any thoughts ?
Old Nov 27, 2007 | 02:38 PM
jakebrake's Avatar
jakebrake
Default RE: Clutch prob when brakes applied
How long have you had this problem?
Old Nov 27, 2007 | 02:54 PM
ahote's Avatar
ahote
Problem just started a day ago while hauling a trailer.
Old Nov 27, 2007 | 03:05 PM
jakebrake's Avatar
jakebrake
If you try letting up slowly on the clutch with your foot on hte brake does it eventually pop into gear? Sorta like letting the input shaft rotate a little to line up splines and shift collars in the trans.
Old Nov 27, 2007 | 03:12 PM
ahote's Avatar
ahote
Doesn't even budge, but as soon as I let off the brake, it slides into gear no problem.
Old Nov 27, 2007 | 04:01 PM
Drew's Avatar
Drew
this is kinda odd seeing that the clutch and brakes have no common part. however I wouldnt rule out the possability of either the clutch master or slave cylinder going out.
Old Nov 27, 2007 | 04:52 PM
ahote's Avatar
ahote
Ya, that didn’t make any sense to me either considering there is no connection. I decided to start the truck up and this time gears shifted fine. I took it for a drive and there was no problem until I came to about my third stop. At this point I was unable to shift gears at all. I turned off engine and put it in to first gear and started it up again. I was then able to drive normally shifting smooth. I have no idea why the clutch would work fine and then not work at all.
Old Nov 27, 2007 | 05:00 PM
jakebrake's Avatar
jakebrake
maybe the pilot bearing is hanging up and keeping the input shaft spinning? Still doesn't relate to brakes though
Old Nov 27, 2007 | 05:22 PM
Drew's Avatar
Drew
the pilot bearing was one of the problems with my yoda. . .along with the syncro's. . .but it was hard to shift all the time. . . .makes me wonder if some of the seals in your master cylinder for the clutch has gone out and are allowing some blow by.
