Getting time to shop for tires...
Old Nov 28, 2007 | 04:53 PM
dwhitney's Avatar
dwhitney
Default Getting time to shop for tires...
Getting time to start tire shopping, would like to go taller but unsure how tall can go on a 2006 3500 4x4 no lift, LT285/LT315/7R17 on the stock wheels or say 20" wheels with what tire?
Dave
Old Nov 28, 2007 | 06:05 PM
energinerbuzzy's Avatar
energinerbuzzy
Default RE: Getting time to shop for tires...
There are a few guys on here that are running 35"s with no lift or level kit, including my self.
You can run up to a 35" tire depending on the wheel and the offset of the wheel.
There are a few recent threads on this if you go back a page or two.
Old Nov 28, 2007 | 11:20 PM
icummins's Avatar
icummins
Depends...example, mine...I had a 2" level kit and the dealer put on 18" 325/65/18 with a +25 offset, not the look I was looking for. I got the same tire size with a 0 offset and they had no chance of fitting. A positive offset will put the tires and wheels closer to the center so the front tires don't swing as wide as if they were towards 0 or even negative. You need to find someone with the same truck and the largest size they put on and find out the offset>>>>the offset is sometimes ignored....good luck
Old Nov 28, 2007 | 11:26 PM
energinerbuzzy
I have 18 x 9 " wheels and a +18 offset with 12.5 wide Pro comps and they fit GREAT.
And FYI , your stock wheels have a +45 or so Offset and like a 6.25" backspacing on the 17" x 8" stock wheel.
Mine for example, are +18 offset and 5.71" backspacing and is a 9" wide wheel. I know that this wheel should work on most stock trucks (4x4) with no lift or leveling needed.
Old Nov 29, 2007 | 07:25 AM
JimmyDiablo's Avatar
JimmyDiablo
ORIGINAL: energinerbuzzy
And FYI , your stock wheels have a +45 or so Offset and like a 4.5" backspacing.
If you mail me your wheels and tires I have a level kit I will try them out and let you konw some research on how they fit. You can write it off as a Christmas expense
Old Nov 29, 2007 | 08:05 AM
cujo's Avatar
cujo
Jimmy, I'm curious. What don't you like about the BFG's you currently have? I've heard you say before that you are not thilled with them.
Old Nov 29, 2007 | 11:29 AM
energinerbuzzy
I don't like the tread pattern. Looks like a brain cut in half......lol
Old Nov 29, 2007 | 04:08 PM
MAB_CTD_4X4's Avatar
MAB_CTD_4X4
I thoght stock wheels had 6.5" of backspacing and +45mm of offset since I haven't seen any rim with 4.5" bs and +45mm os most 4.5" bs rims have -12mm os and with a 2" leveling kit the biggest tire you can run is a 33" since that is what I have on my truck now and looking to change.
Old Nov 29, 2007 | 05:08 PM
energinerbuzzy
OOPS Yes you are correct. I had a brail fart there. The 4.5" is for the -12 offset
I will correct it.
Old Dec 2, 2007 | 07:03 AM
dwhitney's Avatar
dwhitney
So unless I get the new wheels now looks like it's the LT315/7R17for me...
