More Problems
Old Dec 6, 2007 | 09:10 PM
04QC4X4's Avatar
04QC4X4
Default More Problems
I was driving home a few minutes ago and my truck studdered at a stop light. The CEL came on, but it still ran fine. I got home and the codes said P0193 Fuel Rail Pressure Sensor Circuit High Input and P0299 Turbo Underboost. I just had a new lift pump and turbo put on 2 weeks ago. I was getting these exact same codes before. The real problem ended up being a plugged cat. Could my Power Puck be causing these codes? During the time I've been writing this my Quadzilla Recon showed up. I haven't even opened it yet. I took the puck off just to be safe. I guess I'll drive it and if the codes go away then the puck is the problem. The thing that really sucks is that I've had the truck for 5 months and I have not been able to go 2 weeks without a problem.[:@]
Old Dec 6, 2007 | 09:19 PM
nickcoletti's Avatar
nickcoletti
Default RE: More Problems
i have simular codes when i first put my quad XZT in and i was told to unplug the wires and put dielectric grease on the fittings and it cured the problem... my truck even almost stalled on the freeway going about 70 during the time when those codes came up at me but the grease solved it all
Old Dec 6, 2007 | 09:21 PM
04QC4X4's Avatar
04QC4X4
Thats a good suggestion. I really hate to think that I wasted $165 on the puck.
Old Dec 6, 2007 | 09:38 PM
Drew's Avatar
Drew
those codes sound more like you dont have a good connection to your rail and MAP sensors.
nick. . .my truck did shut off. . .good thing I have a stick and was able to keep the power steering and brake booster running till I pushed the clutch in. . .cleaned the ground off and problems went away.
Old Dec 6, 2007 | 10:27 PM
04QC4X4's Avatar
04QC4X4
Yea the puck connects to those two sensors. I'll get some dielectric grease tomorrow along with the 21/64" bit and 1/8NPT tap that I need to install my Recon. By this time tomorrow I should have a working boost, egt, and trans temp gauge.
Old Dec 6, 2007 | 10:33 PM
nickcoletti
goodluck q4qc4x4!
by the way, how long have you had that power puck for? do you like it? im thinking about getting rid of my xzt for that being that its more power and cheaper....
Old Dec 6, 2007 | 10:39 PM
04QC4X4's Avatar
04QC4X4
I got the puck right after I got the truck or about 10k miles ago. My truck has only been running really good for about 2 weeks. Prior to that I had a plugged cat and the thing was a dog. Since I finally got it running I have ran two tanks of diesel. 1 stock, 1 with the puck. Mileage has been exactly the same, but power is greatly improved with the puck. It has much more low end power on either setting. I like the puck because I can switch from stock, to 60 hp, or 90 hp on the fly. I think it is a lot of power for the money. I got mine for $165 at http://www.thoroughbreddiesel.com/diablo/power-puck.htm. It is also really easy to install. It takes about 5 minutes, quicker after the first time.
Old Dec 7, 2007 | 12:55 PM
nickcoletti
if i ever get around to pulling my xzt off i think i am going to list it on ebay so i can try that puck out... my xzt only brought mileage up about 1.5 but only highway miles, the city was no diffrent than b4 i had it so they sound like the same
