a bunch of cr@p!!
Old Dec 10, 2007 | 01:26 PM
Kev_n_AZ's Avatar
Kev_n_AZ
Default a bunch of cr@p!!
I found this article today talkin bout older diesels...he says the Chevy lasts longer than Dodge and that diesels only see 300K....
http://www.a******ia.com/Vintage_Die...cr20060101d1/1
I suggest that you scroll down to "contact us" and choose the LA office. send them an email disproving his claims.
Old Dec 10, 2007 | 04:32 PM
Aero Ram's Avatar
Aero Ram
Default RE: a bunch of cr@p!!
I've seen some old farm cummins with 675k+ on um....my brothers ferd 7.3 mechanical has 275k not bad... almost broke in...
Old Dec 10, 2007 | 05:11 PM
Jr. Mechanic's Avatar
Jr. Mechanic
The guy writing this is effing retarded. The 6.2L was a horrible engine built on a gas block... And he said something about maintance on the fuel system which included replacing the injectors and injector pump if needed. Thats not really simple maintance..
Old Dec 10, 2007 | 05:43 PM
CutterW's Avatar
CutterW
These engines can perform satisfactorily for 300,000 miles and more, under ideal conditions
-He's saying it can last longer but majority of people don't know because they sell it by then.
For a diesel pickup from the early Eighties, probably one of the best choices is the GM 6.2L.
-I thought 12V didn't come out till mid/late Eighties.
Such conditions would include regular oil and filter changes, valve adjustments, fuel system service (including fuel injector and pump replacement, if needed), and cooling system service.
-While yes its not simple maintenence its better than having to replace the whole block.
Old Dec 10, 2007 | 06:33 PM
jakebrake's Avatar
jakebrake
on a 6.2 you will be replacing the whole block because the head gaskets will leak and pit out the fire ring sealing surface on the block. Thats 3out of3 that I have seen anyways. All were taken care of and all had less then 150k on the clock. Junk engine I'd take a 6.9 over it any day.
Old Dec 10, 2007 | 08:44 PM
danthetigerfan's Avatar
danthetigerfan
I had a 96 chevy dually and it gave me 260,000 trouble free miles. Now I have a 07 dodge with the 6.7 .It is a piece of crap! At 10,000 miles the slave cylinder went out. At 30,000 miles the injector pump went out! At 35,000 the U joints went out (so they say....They put a complete drive shaft on) AT 37,000 the clutch went out.( they changed the clutch, pressure platesthe flywheel and slave cylinder...this tells me they know they have a problem) I am not happy with my dependable dodge.[>:]
Old Dec 10, 2007 | 08:54 PM
finny's Avatar
finny
danthetigerfan thats what happens when vehicles first come out. not very often do vehicles start production trouble free. and i am sorry you are having trouble with your truck
Old Dec 10, 2007 | 08:57 PM
07 Ram TRX4's Avatar
07 Ram TRX4
ORIGINAL: danthetigerfan
Boohoo... we all get problem trucks.... I've had plenty of trucks with issues... that's why they warrenty them... **** happens... stuff breaks... 35000 for ujoints? 37000 on the clutch?? I think you may be a bit hard on the drive train.... I have a truck.... have'nt had the clutch adjusted for atleast 25000 miles....maybe even more.... gone over 50000 miles and never had a ujoint fail on me...
Old Dec 11, 2007 | 02:51 AM
Luongo#1's Avatar
Luongo#1
My buddy had an old '84 6.2L Chevy with 750,000 KMs on it. The only thing he ever had to replace was the fuel pump at about 400,000. Other than that, totally problem free.
Old Dec 11, 2007 | 09:38 AM
NCcummins's Avatar
NCcummins
well he is certainly the D.A. of the day!
