Freeze plug
Old Dec 23, 2007 | 01:44 PM
1maddude's Avatar
1maddude
Default Freeze plug
I have a 2004 dodge ram 2500 diesel. I have had to have it towed/returned to the dealership 5 times because the freeze plug keeps blowing out. Anyone with the same problem? Anyone with any suggestions?
Old Dec 23, 2007 | 01:55 PM
triton's Avatar
triton
Default RE: Freeze plug
it's known to happen when you water pressure gets too high. Some have installed plates with a valve and return line back to the radiator.
Some, like myself took a steel plate and blocked the two rear plugs on either side. I had a couple pieces custom cut to do the job. It's very easy to do... just take a steel plate with a couple holes drilled out for the bolts.
Since you're under warranty... I suppose you'll just have to keep going back. The is unless they'll block off the plugs for you... then you be done with it.
Old Dec 23, 2007 | 02:21 PM
1maddude's Avatar
1maddude
Don't understand. Why is the freeze plug blowing out before the radiator cap discharges the pressure? Also, you say you plugged the holes with a custom plate - the plate was then bolted to the block?
Old Dec 23, 2007 | 02:34 PM
triton's Avatar
triton
not sure why buut, it happens all the time. Especially with higher hp engines. Because of running high rpm's the water pump makes more pressure than it should. It may be blowing the freeze plugs because the pressure is in the block after the thermostat. Have you noticed if it does it when cold /hot or anytime ?
here's the kit I mentioned.....
Old Dec 23, 2007 | 03:05 PM
1maddude's Avatar
1maddude
Thanks - I'm just really frustrated with Dodge right now.
