Heater and A/C problems
Old Dec 28, 2007 | 11:55 PM
websterdan's Avatar
websterdan
Default Heater and A/C problems
My selector **** doesn't change the location of air blowing out of my vents. I hear it's a possible blend door or it's motor. Can I access this through the back side of the glove box or how..? This time of year I need the Defrost. I have an extended warranty, but I don't think it's covered....
Thanks
Old Dec 29, 2007 | 12:00 AM
triton's Avatar
triton
Default RE: Heater and A/C problems
I think there is a TSB about your problem. I'd check with the dealer to see before tearing the dash apart.
Old Dec 29, 2007 | 12:06 AM
Drew's Avatar
Drew
ORIGINAL: triton
this is a common problem and yes. . you have to remove the entire dash to get to it. most likely the acuator arm is broken, or the door itself cracked.
Old Dec 29, 2007 | 11:22 AM
KillerCummins's Avatar
KillerCummins
Just had mine replaced under 36/36 waranty. Dropped it off at 8, was ready at 2. Stealer said it was the broken blender door thing. Made me second guess not getting my extended waranty. I'm at 35k and change right now
Old Dec 29, 2007 | 11:37 AM
Kev_n_AZ's Avatar
Kev_n_AZ
when in doubt, take the vehicle in with an extended warranty. if the problem is not covered, maybe they can find somehting else that is so you do not have to pay the minimum fee to look at it.
KillerCummins
you can still buy an extended warranty for the truck.
just look around.
Old Dec 29, 2007 | 02:11 PM
behindbars's Avatar
behindbars
ORIGINAL: Kev_n_AZ
KillerCummins
just look around.
They're out there as long as you got a bunch of$$$$$$. I get a couple ads every week in the mail. DC must sell the **** out of our addresses.
Old Dec 29, 2007 | 02:46 PM
Kev_n_AZ's Avatar
Kev_n_AZ
ORIGINAL: behindbars
ORIGINAL: Kev_n_AZ
KillerCummins
just look around.
my "father in law" just got an offer in the mail for an extended on his 99 3500 ctd.
he called my dodge service guy about the company and they are very reputable.
for less than $1000 (I do not have the exact amount), he has his whole drive train covered now!
especially good since his clutch or input shaftis screwin up.
Old Dec 29, 2007 | 03:08 PM
websterdan's Avatar
websterdan
I have the extended warranty. It covers A/C and heater, but doesn't state blend door or it's motor.
Old Dec 29, 2007 | 04:18 PM
CowboyBob's Avatar
CowboyBob
Check your vacuum pump and lines. It could be a simple vacuum leak or your vacuum pump is bad. The blend doors work off of vacuum.
Old Dec 29, 2007 | 05:00 PM
behindbars's Avatar
behindbars
ORIGINAL: Kev_n_AZ
ORIGINAL: Kev_n_AZ
KillerCummins
just look around.
I called for a quote on several of them and the cheapest one was around $1,800. It didn't cover a lot of stuff and had a $100 deductable. For $1,000 I'd be interested.
