Gear Oil Capacity
Old Dec 29, 2007 | 10:44 PM
zixxer10r's Avatar
zixxer10r
Default Gear Oil Capacity
I just changed out the front and rear diff with Mobil 1 75/90 on my 03 2500. My rear only took 3 3/4 quarts and the front to like 2 1/2 quarts. Is this right I went to about a 1/4 inch below the drain hole. If i add another quart to either diff it will start to flow out. I also measured the used oil and it was roughly what I put in.
Old Dec 29, 2007 | 10:45 PM
Kev_n_AZ's Avatar
Kev_n_AZ
Default RE: Gear Oil Capacity
if it starts to flow out, you have plenty
Old Dec 29, 2007 | 11:46 PM
Parts/Service's Avatar
Parts/Service
2003 CTD
FLUID CAPACITIES
DESCRIPTION
SPECIFICATION
FUEL TANK
Short Box (Lt. Duty)
98 L (26 gal.)*
Long Box (Lt. Duty)
132 L (35 gal.)*
ENGINE OIL WITH FILTER
3.7L
4.7 L (5.0 qts.)
4.7L
5.6 L (6.0 qts.)
5.7L
6.6 L (7.0 qts.)
5.9L
4.7 L (5.0 qts.)
8.0L
6.6 L (7.0 qts.)
5.9L DIESEL
11.3 L (12.0 qts.)
COOLING SYSTEM
3.7L
15.4 L (16.2 qts.)**
4.7L
5.7L
15.4L (16.2 qts.)**
5.9L
15.5 L (16.3 qts.)**
8.0L
24L (24.3 qts.)**
5.9L Diesel Engine
28L (29.5 qts.)**
POWER STEERING
Power steering fluid capacities are dependent on engine/chassis options as well as steering gear/cooler options. Depending on type and size of internal cooler, length and inside diameter of cooler lines, or use of an auxiliary cooler, these capacities may vary. Refer to 19, Steering for proper fill and bleed procedures.
AUTOMATIC TRANSMISSION
Service Fill - 46RE
3.8 L (4.0 qts.)
O-haul - 46RE
9-9.5L (19-20 pts.) ♦
Service Fill - 47RE
3.8 L (4.0 qts.)
O-haul - 47RE
14-16L (29-33 pts.) ♦
Service Fill - 48RE
3.8 L (4.0 qts.)
O-haul - 48RE
Service Fill - 45RFE/545RFE
4X2 - 5.2 L (11.0 pts.)
4X4 - 6.2 L (13.0 pts.)
O-haul - 45RFE/545RFE
14-16 L (29-33 pts.) ♦
♦ Dry fill capacity Depending on type and size of internal cooler, length and inside diameter of cooler lines, or use of an auxiliary cooler, these figures may vary.
MANUAL TRANSMISSION
NV3500 4X2
2.3 L (4.8 pts.)
NV3500 4X4
2.0 L (4.2 pts.)
NV4500
3.8 L (8.0 pts.)
NV5600
4.5 L (9.5 pts.)
TRANSFER CASE
NV241 GENII
1.6 L (3.4 pts.)
NV243
1.6 L (3.4 pts.)
NV271
1.89 L (4.0 pts.)
NV273
1.89 L (4.0 pts.)
FRONT AXLE ± .03 L (1 oz)
C205F
1.66 L (3.5 pts.)
9 1/4 AA
2.25 L (4.75 pts.)
REAR AXLE ± .03 L (1 oz)
9 1/4
2.32 L (4.9 pts.)***
10 1/2 AA
2.25 L (4.75 pts.)
11 1/2 AA
3.62 L (7.65 pts)
*** With Trac-Lok add 118 ml (4 oz.) of Limited Slip Additive.
** Includes 0.9L (1.0 qts.) for coolant reservoir.
*Nominal refill capacities are shown. A variation may be observed from vehicle to vehicle due to manufacturing tolerance and refill procedure.
Hope this is not too confusing, but It won't let me post the nice graph thing in the manual and this is how it turns out when I try...
Old Dec 30, 2007 | 08:21 AM
Blue Ridge Transport's Avatar
thats very helpful thanks im gpoing to print it i think thanks again... and since you work at dealer amybe you can tell me if you guys could or would change outBOTH axel sealswith only 57,000miles on truck even if just one side is leaking?? Im going to be droping mine off tonight at dealer and would like them to do both sides since i dont have to pay for oarts and labor. Other thing is it an 2003 ram 3500,drw,all stock with 57,000 is there anything eles or any recalls that i need to know about?? Thanks for any info im all new to the rams.Thanks again man Allen.
