Ty, maybe you can answer this. . .hopefully
alright. . .I loaded SW5 to see how she worked and OMG that was some serious injector rattle. . so much so I didnt make it out of my driveway before going down to #4. anyway, something I noticed. . .I hit 20-25psi and I loose all boost. . .my TST is off and the boost limit is also off, and my boost goes from 20-25 down to 15-18 and no throttle responce above 2200rpm. I turn the TST on and it did help a bit, but still not what I had at the SC dyno day. I try SW6 and still nothing. . .removed smarty to stock and everything cool again when I set my TST to 4/3. with smarty, booost was slow to build, acceleration just wasnt there above 2K. I know I can fuel to 3K even with my stock setup with the TST crunk. . .
any options. . .I'm currently flashing a different software with a moderate torque managemnt to see if that help.
lemme know
lemme know
RE: Ty, maybe you can answer this. . .hopefully
I don't really know what that could be Drew. I've never encountered a " low " boost issue like that. Even if you had older SW on the smarty it should have done that. The SW you linked too is the lastest that's out. Try it to see what happens and if there's still a problem, Bob should be able to help. I'll write him anyway to ask about this and to maybe be on the look out for a email from you.
Trending Topics
