Transmission trouble
Old Dec 31, 2007 | 06:35 PM
white fury's Avatar
white fury
Default Transmission trouble
OK, today is the first time I 've had any problems with the truck, I'm going on 12500 miles since 11/26/07. I put it in gear and it takes about a second to engage. I didn't know this and gave it some throttle and jerked something nasty. Now it does it everytime I go into drive and once in a while during regular driving it will kinda slip. Any Ideas on what it might be. I will be taking it to the dealership on Wednesday.
Old Dec 31, 2007 | 07:18 PM
amock's Avatar
amock
Default RE: Transmission trouble
I would probably say your bands need adjusted, especially since the jerking happened.
Old Dec 31, 2007 | 07:19 PM
triton's Avatar
triton
I have to ask the obvious but, you did check the fluid level ?, that's what it sounds like. Being as new as it is, that's usual to have trans problems already. You may also have a flash out for your truck that could take care of it. Be sure to ask the dealer about that.
Old Dec 31, 2007 | 07:35 PM
white fury's Avatar
white fury
Thanks I feel that it is way way way toooooo early to have transmission problems. I have not even pulled a trailer yet. Heaviest load has been about 1800 lbs. 90% highway miles Will go ahead and check the fluid before I go to the Dealer.
Old Jan 9, 2008 | 12:13 AM
dharley's Avatar
dharley
So what did the dealer say about this tranny issue? Is it a auto trans?
Old Jan 9, 2008 | 12:17 AM
nickcoletti's Avatar
nickcoletti
i have had very simular things happening to my trans and i was thinking it was from my xzt module...... im curious to see whats making your truck do that[:-]
Old Jan 9, 2008 | 12:26 AM
Cumminnotstrokin's Avatar
Cumminnotstrokin
Mine is in the shop right now for a similar problem 1-2 slipping back and forth. My 98.5 would do that when it would set for a few days, I would put it in neutral and let the torque converter fill up. But yours is brand spankin new
Old Jan 9, 2008 | 07:03 AM
white fury's Avatar
white fury
Have not gone yet but will update as soon as I get it over there.
Old Jan 9, 2008 | 10:16 AM
Master Baiter's Avatar
Master Baiter
ORIGINAL: Cumminnotstrokin
Not to highjack the thread, but what ever came out of this? Mine does this a lot, took it to the dealer twice and they say it "shifts normal".[sm=confused06.gif]
Old Jan 9, 2008 | 10:26 AM
Cumminnotstrokin
I will let you know as soon as I get it back. Hopefully today
