cummins injector pump ?
Old Jan 2, 2008 | 07:30 PM
bluecummins's Avatar
bluecummins
Default cummins injector pump ?
If the truck has better than 100 thousand should it be changed before performance is done ?
Old Jan 2, 2008 | 07:56 PM
CowboyBob's Avatar
CowboyBob
Default RE: cummins injector pump ?
I would not change the injector pump until it quits working or starts throwing codes in the computer. The lift pump is what needs to be changed, especially if you plan on hot rodding the engine. Walbro and FASS seem to be the popular choices around here.
Old Jan 2, 2008 | 08:00 PM
Drew's Avatar
Drew
just as bob said. . .as long as you keep fuel to the VP44 it'll run well.
Old Jan 2, 2008 | 08:02 PM
bluecummins
the injector pump went out and never threw any codes i put edge juice on it 2 days later it died and both pumps are done
Old Jan 2, 2008 | 08:26 PM
CowboyBob's Avatar
CowboyBob
Sorry to say this but.....More than likely your lift pump died and it took the injector pump with it when the injector pump starved for fuel. I'd suggest investing in a good fuel pressure gauge. When you find out how much the injector pump costs, your gonna wish you had.
Old Jan 2, 2008 | 08:29 PM
bluecummins
oh i no like 2000 grand but the edge has a good gauge it was weak it has 150 thousand miles so i no it was weak when i put the edge juice on there do u think it was still runing on just the injector pump ?
CowboyBob's Avatar
CowboyBob
Also forgot to mention that there are probably codes in the ECM but the "Check Engine Light" may not be on. If you don't have a code reader, click your ignition 3 times "on-off" real fast but don't start the truck. On the third "on" click leave the key in the on position and look at your digital odometer. It will start showing numbers that start with the letter "P". Post those numbers here and we can tell you what they mean.
Old Jan 2, 2008 | 08:33 PM
CowboyBob's Avatar
CowboyBob
Yes it is possible that the truck was running on the injector pump alone. If this were the case, you wouldn't go more than about 5Mph. If you think that the injector pump may still be good, then do not start the truck again until the lift pump is fixed.
When my first lift pump died the truck would idle fine, but when you stepped on the gas, it would not go more than 5MPH. Luckily I did not ruin my VP44. I have 177k miles on the original one.
Old Jan 2, 2008 | 08:38 PM
bluecummins
well then they had to of went out at the same time becuz up until it died it was runing good like i turned up the edge and got it sideways then i let off and it died it will not start at all so they are both gone i think
Old Jan 2, 2008 | 09:23 PM
Kev_n_AZ's Avatar
Kev_n_AZ
go to
www.mwfi.com for your vp44 fi pump. free shipping too!
