What size hole to drill for pyro?
Old Jan 3, 2008 | 07:29 PM
sallyman1's Avatar
sallyman1
Default What size hole to drill for pyro?
what size hole to drill for pyro for a edge juice attitude? what size drill bit and what tap to use?
Old Jan 3, 2008 | 07:40 PM
Drew's Avatar
Drew
Default RE: What size hole to drill for pyro?
cumminalong has a faq on just this
Old Jan 3, 2008 | 07:53 PM
finny's Avatar
finny
it is stupid i have been trying to figure out what thread is on the probe. no one knows!!![:@] they said it might be the same as an o2 sensor.
Old Jan 3, 2008 | 08:00 PM
solarwarp's Avatar
solarwarp
Mine was a 1/8" NPT; someare 1/4" NPT.... it's not what most are accustumed to being a normalnut and bolt thread.
It's a pipe thread. NPT=National Pipe Thread. I found the tap at Lowes. I don't remember the drill size.
Old Jan 3, 2008 | 08:25 PM
CowboyBob's Avatar
CowboyBob
I believe the recommended drill bit size for a 1/8 NPT tap is 11/64" not too sure so better double check. A lot of the taps you buy nowadays have the drill bit size on the tap.
Old Jan 3, 2008 | 08:30 PM
burban2002's Avatar
burban2002
I just bought one of these taps today at napa (1/8 pipe tap). It says to use a 11/32" drill bit, but the instructions on genos say 5/16" and autometer say to use a 5/16" type R which is right inbetween the other 2. I'm going to try the 5/16" first and see how it goes tomorrow
Old Jan 3, 2008 | 08:50 PM
Drew's Avatar
Drew
caleb. . .go with the 11/32, heck if you can find a 23/64 that would be even better. . .I think I have one laying around the house that I used.
the reason I say this is that the slightly larger size will reduce the material the tap has to go through thus makeing it easier for the tap to cut the threads
Old Jan 3, 2008 | 09:07 PM
burban2002's Avatar
burban2002
Wow, thanks for the tip drew, that didnt even cross my mind. I'll go with the 11/32; I dont think I have a 23/64 lyin around. My concern was that if I went with the bigger bit, there wouldnt be enough material to tap, but not anymore
Old Jan 3, 2008 | 09:27 PM
04QC4X4's Avatar
04QC4X4
I just did this a few weeks ago and if I remember correctly I think it was a 21/64" bit and a 1/8 NPT tap. I drilled a 1/8" pilot hole and it helped a lot. Also be sure and leave the engine running when you drill and all of the shavings will be blown out instead of falling into the manifold. When I was tapping the hole I just put some grease on the tap instead of running the engine (this took a few minutes).
Old Jan 3, 2008 | 10:13 PM
jedrph's Avatar
jedrph
I believe I had a 1/8" npt on mine. used "r" size drill. I believe the drill itself is tapered as is the the tap, not a straight tap like a nut. however 11/32or 21/64should work. R is int between the two.
