rear end ratio
Old Jan 10, 2008 | 07:44 PM
dasnake's Avatar
dasnake
Default rear end ratio
i think this has been asked before but i can't find it, is the 4.10 ratio an option? and if you had that gear setup would it be marked on your dealer prep sheet? my '07 ctd 4x4 has posi, which is marked on the dealer sheet, but from what i understand the 3.73 ratio is standard, and that i would surmise is what i have, any help would be great.
Old Jan 10, 2008 | 08:01 PM
04QC4X4's Avatar
04QC4X4
Default RE: rear end ratio
Should be on the dealer's window sticker, or I think you can open the glovebox and there is a sticker that has the info on the gears. (I think). I know I saw a sticker somewhere in the cab.
Old Jan 10, 2008 | 08:04 PM
Parts/Service's Avatar
Parts/Service
PM the last 8 digits of your VIN and I can tell you which gears you have.....
Old Jan 10, 2008 | 08:45 PM
dasnake's Avatar
dasnake
04, i can't find anything, i looked at all tags, thanks.
parts, coming at ya, thanks.
Old Jan 10, 2008 | 08:59 PM
Drew's Avatar
Drew
if it is an 04 the build sheet will be in the glove box and it will state if you have 4.10's. if you have 3.73's nothing will be listed.
Old Jan 10, 2008 | 09:31 PM
dasnake's Avatar
dasnake
thanks all, parts filled me in, just shows you the knowledge on this forum.
Old Jan 10, 2008 | 10:09 PM
Mr.Inferno's Avatar
Mr.Inferno
I have an 06 1 ton dually 6 speed manual, and I don't have any indication of what kind of rear end is in my truck. I'm thinking I have 4:10's. due to the fact that at 75mph my rpms' are about 2300-2400. My bro who has a 06 ford has the 3:73's or whatever Ford has says at the same speed he's at 2200 rpms. Not much of a difference I didn't think. He would rather have the lower ratio for pulling is monster camper.
Old Jan 10, 2008 | 10:43 PM
dasnake's Avatar
dasnake
that's my whole mix, with 3.73 i'm at 13,500 lbs. with 4.10 i raise the bar to 15,500, well worth the 2 grand to change everything over. that also gives me an eighty grand truck, what da **** it's only money.
Old Jan 11, 2008 | 09:27 AM
Drew's Avatar
Drew
ORIGINAL: Mr.Inferno
you actualy have 3.73's. All manual shift trucks built after Jan 05 have the G56 transmission, and due to the gear ratios of the G56, the 4.10 ratio would be geared WAY too high to even think about running on the highway. Those trucks built before that however have the NV5600 tranny and have the option of 4.10's.
Old Jan 11, 2008 | 11:30 AM
steve05ram360's Avatar
steve05ram360
ORIGINAL: dasnake
2 grand sounds kinda pricey... ran me 1250 in my 2000 gasser... shouldnt be much more than that...
