Running the stock setting...
Old Jan 17, 2008 | 11:47 PM
steve05ram360's Avatar
steve05ram360
Default Running the stock setting...
for comparison purposes against the MPG thread data that I have. Suprising numbers so far... I was figuring on upper 16's but there is no way it's that low. 200 miles on 1/8th of a tank. 195 was about it previously...
Old Jan 18, 2008 | 12:26 PM
squirtbottle09's Avatar
squirtbottle09
Default RE: Running the stock setting...
I get 22mpg on average cruising ~80 on the highways. Completly stock
Old Jan 18, 2008 | 08:07 PM
steve05ram360
ORIGINAL: squirtbottle09
yup, if I had stock tires on i'd be in the low 20's as well...
Old Jan 18, 2008 | 08:26 PM
bert0168's Avatar
bert0168
If I am reading it right, are you running in tow/haul mode as well as using the programmer?
Old Jan 18, 2008 | 09:55 PM
Drew's Avatar
Drew
hey sheve, check this one out. . .been running smarty #4(90hp no timeing) and my TST on 2/2(425hp) and got 17.9mpg. . .realy, this falls within my normal mileage range with just the TST at 4/3 (375hp).
I'm running just the smarty on #4 right now with the TST off to see any difference.
Old Jan 18, 2008 | 11:51 PM
steve05ram360
Yup, 90% of the time I remember to fip the switch for tow haul mode.
Drew, I'm curious to see what you get with just the smarty. I still have it on my list of mods to get (will probably be my next one) and would like to get more feedback with the mileage info for it.
Old Jan 19, 2008 | 11:25 AM
Drew's Avatar
Drew
I can already tell you this. . .smarty on the 90hp setting has WAY more low end than the TST on 4/3 does. granted the top end isnt as great, it would certianly help with your studies on how to gain your low end back
Old Jan 19, 2008 | 08:09 PM
bert0168's Avatar
bert0168
I'm curious, what does that do to low and high end?
I know it basically changes the shift points, but I only ever run it while I'm towing.
Old Jan 20, 2008 | 07:02 PM
steve05ram360
It changes the shift points and the torque converter lockup.
Well, filled er up today... 17.9 mpg over 571 miles. I am suprised...
Old Jan 20, 2008 | 08:16 PM
bert0168's Avatar
bert0168
OK, I am going to sound dumb, [8D]but what exactly is "torque converter lock up" and where should I expect itin an auto with the 3.7? rear.
If it's what I think it is, it seems to be around 50 mph
