question on getting heater to work
Old Jan 24, 2008 | 08:54 PM
slick515's Avatar
slick515
Default question on getting heater to work
i have flushed system also changed thermostat,also flushed heatercore hand dont get off 140 as of now during winter then it may warm up just shade past 140 after running 3 to 4 hrs then its just bareley warm any ideas or help be appreciated
Old Jan 24, 2008 | 09:01 PM
Drew's Avatar
Drew
Default RE: question on getting heater to work
I know it sounds like a silly question. . .but did you get the thermostat installed correctly.
second, you may have a hydrolock situation in the head causeing the thermostat to not open. or have water circulate properly. do you have an EGT gage and monitor it???
Old Jan 24, 2008 | 09:04 PM
slick515's Avatar
slick515
have no egt gauge yes its in correctley i can get just little heat after very long time but not hot just lil warm and i also have radiator blocked have way off still dont help much so what can be done?
Old Jan 25, 2008 | 11:36 AM
DBLR's Avatar
DBLR
You have to remember that it takes time to heat up 7.5 gallons of coolant and then 1,000 lb of steel. The other day it was -21.9 below zero, block heater plugged in for 4 hours, my Dodge winter front had all 4 flaps closed off, back it out of the garage and drive 4 blocks around to the front of the house for 5 minutes of high idel time. Then a drive to town at speeds between 50 and 60 MPH. It took my truck a good 18 miles before the temp guage showed full operating temp. BTW after 4 hours of it being plugged in and 2 minutes of idel time I get 50 degree heat from the vents with fan speed on 1.
