How to use or read ATTITUDE and PYRO??
Old Jan 27, 2008 | 08:49 PM
Drew's Avatar
Drew
Default RE: How to use or read ATTITUDE and PYRO??
boost numbers are right
Old Jan 27, 2008 | 10:09 PM
sallyman1's Avatar
sallyman1
maybe the pyro is just sensitive which it should be. When you guys race or hammer down throttle r u actually going to the floor? I can accelerate hard gradually without going to floor and egts will just stay around 900-1050 or so. If i mash it right to floor itll climb FAST. if i turned alarm and max off I bet i could easily hit 2200
Old Jan 28, 2008 | 10:04 AM
Drew's Avatar
Drew
Ive got to shift before my foot hits the floor most of the time
Old Jan 28, 2008 | 10:12 AM
Methos's Avatar
Methos
ORIGINAL: sallyman1
Bet you can't! Seriously doubt your engine would survive long enough to reach that temp. Just ask Triton. [sm=badbadbad.gif]
(no offense intended toward Triton)
Although, if you get it there, we'll want pictures of the aftermath....
Old Jan 28, 2008 | 01:10 PM
Mayfair's Avatar
Mayfair
ORIGINAL: sallyman1
My truck is in signature below.
What sig ??
Can't you guy's reset the alarm temp to higher numbers on the Attitide?
Old Jan 28, 2008 | 05:27 PM
sallyman1's Avatar
sallyman1
truck is a 2004.5 dodge ram 2500 diesel 4X4 quad cab short box, ****** whistler cold air intake, 4" turbo back with aero4040xl,
Old Jan 28, 2008 | 05:28 PM
sallyman1's Avatar
sallyman1
it was -35 celcius today with windchill. could it be the cold air intake making my egts and psi high? should i block off the air hole in fender for winter driving?
Old Jan 28, 2008 | 06:33 PM
Drew's Avatar
Drew
if anything the cold temps would bring down EGT's.
these 3rd gen engines are built to withstand 1300 all day long without any problems. 1400 is when things get a bit funny, but that is sustained, short bursts up to 1500 are ok. .. but only for a short burst as damage to the valve ring will occur if sustained without proper mods.
Old Jan 28, 2008 | 06:51 PM
Big Gib's Avatar
Big Gib
man i got the edge with attitude and mine on my '01 and mine runs exactly like yours. u can use the attitude to change your egt alerts. thats what i did.
Old Jan 28, 2008 | 08:35 PM
sallyman1's Avatar
sallyman1
EDGE told me today to test my pyro with ohmeter and test for 1.5 to 3.0 ohms. So I will. They also said unhook pyro (2 screws) and drive around and see what attitude says. if it says same values and rises quickly its my juice ecm. if nothing at all happens then its the pyro.
