Recon cab Lights
#52
RE: Recon cab Lights
Give it about a mounth and u will be cussing recon trust me. I had 3 sets of them and nothing but problems. Something to do with the LEDs you'll have one dim and the others will work right. I got tired of sending them back and just put the stock ones back on. Hope you have good luck.
#53
#54
ORIGINAL: agargano98
sweet, i am ordering them right now. thanks for the promo code, you realy hooked us up. $59.46 and free ship. you cant beat that price anywhere. they are going for $69.99 +$13 shipping on ebay
#55
#57
negatives on Recon cab lites.
Factory lights are slightly curved on the bottom to match the roofline. Recon aren't, and when you put them on and tighten the screws the roof deforms slightly and is noticeable.The gasket system on the factory is excellent. I tried using the gasket on the recons , but because they are flat it wouldn't seal properly.Recon should redesign with a better fit.
#58
#59
ORIGINAL: Az2500Cummins08
mine fit just fine with the stock gaskets. The supplied screws with the recon lights suck. I used the stock screws. Bigger heads, so I could tighten them down more without the rubber washers tearing.
