Can winter front give you HIGH EGTS?
In canada its -50 celcius right now where I live. I have 2 layers of cardboard covering the rad area. Could this be why my juice attitude is giving me high egts? Im hitting 1450ish on stock levels and worse on levels 1-6.Should I remove it? or is something else wrong?
RE: Can winter front give you HIGH EGTS?
Allthat cardboard and winter fuel, I have stainless steel grill inserts on my truck and I ahve seen both the boost and EGT up over what I see in the warmer weather! Normally at hwy speed 65-75mph (100-140kph) in the warmer weather boost is at 8-10psi and EGTs runnin 700-800deg in colder weather boost runs around 10-13psi and EGTs 800-950deg.
ORIGINAL: sallyman1
i get you. but by covering entire rad area like i did with cardboard and i mean COVER< is that why my egts are possibly really high?
where are you in our wonderful country.
i removed ALL CARDBOARD and same thing. its a little better. The question I have is with you guys with chips/modules do u mash pedal to floor or gradually press it? if i mash pedal on level 0 or 1 it will beep and hit 1450 in 4 seconds flat. If I gradually press accelerator to floor I can go way longer without them hitting.
