Ball joint replacement??'s
Old Feb 13, 2008 | 09:14 AM
Hutch98's Avatar
Hutch98
Default Ball joint replacement??'s
Have a 99 2500 CTD 4x4 and tackling the ball joint's this weekend and checking to see if people that replaced them in the past used a universal ball joint press or know the size of the installation tubes needed to press them back in. Also is there a good detailed write up?? I did the search but not the greatest info. I have replaced them on D44 axles but the hubs and spindles came off alot easier than these will/do. Thanks for the help.
Hutch
BTW will be getting the Moog ball joints
Old Feb 13, 2008 | 09:57 AM
Drew's Avatar
Drew
Default RE: Ball joint replacement??'s
if you havent looked yet. . .head over to TDR, I believe someone over there has done a write up on them.
Old Feb 13, 2008 | 11:20 AM
apappal's Avatar
apappal
Just replaced mine on my 04, not sure what the difference in axles are but used a basic ball joint press kit, no real problems other then breaking the one speed sensor. I put the moog greasible in, I only wish they made a non-adjustabel upper.
Old Feb 13, 2008 | 01:26 PM
Hutch98's Avatar
Hutch98
What is TDR??
Old Feb 13, 2008 | 01:56 PM
Drew's Avatar
Drew
ORIGINAL: Hutch98
What is TDR??
Turbo diesel Register. . .I'm also a member over there.
