replacing 4x4 actuator? could use some input
Old Feb 15, 2008 | 06:53 PM
bballmac42's Avatar
bballmac42
Default replacing 4x4 actuator? could use some input
Im told my 4x4 actuator is bad, hence why the 4wd wont actuate. Anyone done this? is it a pretty easy fix? p.s. 98 CTD 2500
Old Feb 15, 2008 | 07:48 PM
burban2002's Avatar
burban2002
Default RE: replacing 4x4 actuator? could use some input
man that sucks, the hits just keep on coming. I'll look and see if I can find something.
Old Feb 15, 2008 | 08:18 PM
bballmac42's Avatar
bballmac42
tell me about it...its beena nightmare so far. Im not off of dodge by any means, but im thinking of almost getting rid of it to avoid any other issues once i fix it. Is it normal to not be blowin any black smoke? I was told it has different injectors, and i know the tst box is unplugged, but shes not blowin any that i can tell. Just wondering if thats normal for basically a stocky
Old Feb 15, 2008 | 08:40 PM
dirtydodge02's Avatar
dirtydodge02
Mine hardly blows any black smoke either. I have to really get into it to get any. Frusterating cuz I know that something isn't right....
Old Feb 15, 2008 | 10:28 PM
burban2002's Avatar
burban2002
The actuator is a pretty easy fix. Its a box shaped object with two lines running into it. One should be red and one should be black. Make sure the vacuumlines are still attached to it. When in 2wd one should have the vacuum and in 4 wd the other should. The unit itself should just unbolt and the new one bolts in. Becareful because most likely the bolts are a bit rusted.
Old Feb 16, 2008 | 01:58 AM
bballmac42's Avatar
bballmac42
thanks burban, im probably gonna tackle it tommorow and HOPE that is takes care of it. Have a possible foot of snow coming on sunday and 4wd would probably be nice About the smoke, even when i get on it, i am not trailin any..is this a good thing? meaning no unburnt fuel? or should i be makin some? im not pushin any extra fuel with fass or anything, just a stock pump, but it does have stage 2 injectors
Old Feb 17, 2008 | 02:34 AM
bballmac42's Avatar
bballmac42
i have four wheel drive! yessssss. what a relief that was to see that light come on and have the 4wd engage. AND i got the track bar in, the outer connecting tie rod (the one to the pitman arm),tie rod-end and adjusting sleeve on. 1000% better on the steering. overall a good night for the truck thats been all problems.
Old Feb 17, 2008 | 09:34 AM
burban2002's Avatar
burban2002
sweet man I'm glad it worked out for you. It sure is nice to have 4wed when you need it. I think the extra smoke is from your injectors and not really a big problem. Mine doesnt smoke much, but its also pretty much stock (for now). Do you have gauges on your truck?
Old Feb 17, 2008 | 11:42 AM
steve05ram360's Avatar
steve05ram360
a stronger fuel pump like a FASS or Walbro kit may help with the smoke... better fuel pressure will ensure that the injection pump does not starve for fuel under high demand
