auxillary fuel tank
Old Feb 19, 2008 | 12:26 AM
sanddragonslayer's Avatar
sanddragonslayer
Default auxillary fuel tank
does anyone have any pictures, of tanks in the bed? are you guy using them to fuel equipment? Or just to extend your range? I am thinking of doing something simple, I am invisioning a ball valve for shut off. W/ a direct line to the filler neck of the stock tank. anyone have any ideas? I did a complicated transfer system for a gaspowered dually when I was still driving for the race team, but i don't think that I need all that.
Old Feb 20, 2008 | 10:39 PM
CowboyBob's Avatar
CowboyBob
Default RE: auxillary fuel tank
WTF? I put a response to this and now Isee it has 0 replies and my response is gone. WTF?
Old Feb 21, 2008 | 12:16 AM
sanddragonslayer
I don't know, I didn't get to see it!?
Old Feb 21, 2008 | 07:06 PM
CowboyBob's Avatar
CowboyBob
I'll get some pics of the tank and re-type the post I did earlier, maybe I forgot to hit save.
Old Feb 21, 2008 | 07:19 PM
Bigriver's Avatar
Bigriver
This is the Transferflow 50gal. model. It's very convienent, has a computer moduale in the cab that pumps fuel to the main tank automaticly. The computer works to keep an equal balance of fuel in percentages. Meaning......when I'm down to 3/4 full in the main, so is the aux. I've had it over a year with no problems. I bought it for the extended range that it gives me.
__________________________________________________ ______________________________
Old Feb 21, 2008 | 07:36 PM
fearless's Avatar
fearless
I have my tank hooked up the same way as you are wanting to hook your up, with a ball valve and it works great. Have never had a problem with it. Bought all the parts at Home Depot.
Old Feb 22, 2008 | 05:56 PM
CowboyBob's Avatar
CowboyBob
The only problem I had was the sending unit was not on tight and it would leak about a 4 in dia puddle on the ground overnight if I left the valve open. After tightening it, no more problems.
Old Feb 22, 2008 | 06:01 PM
CowboyBob's Avatar
CowboyBob
This is the only picture I could find. Mine is 90 gallons. It was custom made by a welder friend to fit in the space between the wheel well and front of the bed, and also be flush with the top.
[IMG]local://upfiles/23352/6C7CF1C713454B17821A1E0EBB3FFD1C.jpg[/IMG]
Old Feb 22, 2008 | 08:06 PM
JD1500's Avatar
JD1500
i used to run a transfer flow as well. I loved it. It was diamond plate, looked just like a tool box. only bout enough room in it for some gloves and a chain or two. but it worked real good. was in the 80-100 gallon range.
Old Feb 24, 2008 | 12:38 AM
sanddragonslayer
thx for the info guys!!!
