Gas motor swap, to a 4bt
Old Feb 20, 2008 | 11:33 PM
honda450r's Avatar
honda450r
Default Gas motor swap, to a 4bt
Just wondering if anyone had any helpfull advice for my swap. I wanna put a cummins 4bt in place of my 360 gas motor. The truck is a 95 3/4 ton standard cab long box. Also if anyone has a running 4bt i would like to pay cash for it. Thanks for any info!
Old Feb 21, 2008 | 12:17 AM
JR 06's Avatar
JR 06
Default RE: Gas motor swap, to a 4bt
Why not just go for a 12 Valve instead of the 4BT? the 12 Valve will make alot more power and should be alot easier to swap.
Old Feb 21, 2008 | 11:16 AM
honda450r's Avatar
honda450r
Yeah that is somthing im considering too. Im in SD and im havn a hell of a time finding any motor thats worth a crap. I either want to sell the truck now or swap motors and keep it. a 12v out of a 96'-98' would be best wouldnt it?
Old Feb 21, 2008 | 04:23 PM
rootercycles's Avatar
rootercycles
better off (and a lot cheaper) to just look for a truck that is already set up with a CTD. You'll save yourself a lot of headaches and expense trying to convert your current rig. Now if you like to do crazy stuff like that, go for it! I have done a lot of things with different vehicles such as convert a van to 4X4 (I wouldn't recommend it), put a foot clutch and hand shift on a chopper with 20" ape hangers (wouldn't recommend it) and built a stock bike with a 140hp engine (definitely recommend it!)
Old Feb 21, 2008 | 04:50 PM
Drew's Avatar
Drew
4bt is a good motor. . but if your gunna do it, do it right and find a 12 valve out of a 94-98.4 2500 and work the injector pump over a little. . .you may have to upgade the rear axel after a few hard launches, but it sure will be fun
Old Feb 21, 2008 | 10:18 PM
Deleted User's Avatar
Deleted User
Default [Deleted]
[Deleted by Admins]
