cummins idle s itself up
Subscribe
Feb 28, 2008 | 12:02 AM
RE: cummins idle s itself up
Quote:
ORIGINAL: 05cumminscrx
where can i buy this part, how much should the dealer charge to do this, what isa safe idle rpm for all night in these cumminws? also is there a flash out there that can enable the power in the cabin util a door is opened thanks for the info
You do have the manual trans right? Email me chris7694@gmail.com I'll send you a full writeup with pics and part#. Very easy to do andonly takes a few minutes. The dealer would want $400 to install the wire. Since you're gonna DIY the wire andonly gonnaneed a flash at the dealer it shouldn't cost you anymore than $30 to $75 is what I've heard reported... Some of the cooler dealers won't charge anything...
I'd bump it up to 1100 rpms for overnight and forget about it. I only use faster than that to warm up or cool down the cab on startups...
Reply 0
Feb 28, 2008 | 02:33 PM
Quote:
ORIGINAL: 12valveman
like the guys said this is normal but if you pay close attention the truck is also switching and running in 3 cylinder mode alternating the cylinders to create heat faster. and i am sorry to say if you do not have you electrical option i do not belive you can turn it on i could be wrong but have never heard of it added or turned on
FYI, only the trucks with the V pump can go in to 3 cylinder mode aka 3 cylinder shuffle.
Reply 0
Subscribe
