Fuel Problem?
Old Feb 28, 2008 | 12:02 AM
soniclm's Avatar
soniclm
Default Fuel Problem?
I have a 2001 Cummins and it auto. I have this problem that started the other day is that if I idle crusie and I tap the gas a little bit real quick, it likes heitates. It doesnt do it when I driving just like goin slow. I have replaced the lift pump several months ago and my trucks runs just fine other then that and it ussually starts up right when I bump the starter and that is how its been since I've had it for 22,000 miles. The fuel was chaged several months ago too and the lift pump is located on the engine.
Old Feb 28, 2008 | 02:19 AM
Mayfair's Avatar
Mayfair
Default RE: Fuel Problem?
Do you hafta bump the starter every time to fire it up?
Old Feb 28, 2008 | 07:34 AM
soniclm's Avatar
soniclm
I forgot to add that my lift used to turn of and run for like 10 seconds my now it turnes one for like one second when I turn the key, if I bump it over, it'll run for about 10 seconds. I mean I just need to bump the starter and its starts right up, it doesn't crank over and over to start.
Old Feb 28, 2008 | 06:11 PM
soniclm's Avatar
soniclm
Does anyone have an idea?
Old Mar 3, 2008 | 09:59 PM
Parts/Service's Avatar
Parts/Service
I thought that when you just turned the key to the on position that the transfer pump only ran for 1 to 2 seconds and when you bumped the starter, the transfer pump ran for a longer peiod of time...As fas as the hesitation, I do not have a good answer, but I will get with my diesel tech tomorrow and pick his brain....
Old Mar 3, 2008 | 10:06 PM
soniclm's Avatar
soniclm
Thanks for your help so far and I also changed the fuel filter today and that isn't the cause.
Old Mar 3, 2008 | 10:24 PM
Drew's Avatar
Drew
so you replaced the lift pump with the same stock pump???
I'm wondering if you either 1, got ahold of a bad lift pump, or two your VP44 is weak.
Old Mar 3, 2008 | 11:19 PM
soniclm's Avatar
soniclm
I replaced it with a stock lift pump, when the lift pump went out last time, it didn't do this, I think we replaced back in august maybe
