Carter Fuel Pump Problem
Old Mar 3, 2008 | 02:34 PM
CowboyBob's Avatar
CowboyBob
Default Carter Fuel Pump Problem
A guy here at work bought a 2001 with a CTD last thursday. Over the weekend it became hard to start. It blows white smoke while trying to start and eventually starts. He took it to a shop down the street from work and they said that it has 2 lift pumps. The old carter pump AND one in the tank. They said the pump in the tank is weak.
His dual pump setup is not like mine. The 2 pumps are hooked up in series and it appears that the in-tank pump was pushing fuel through the dead carter pump. Has anyone heard of this? Did he buy the truck from some half-*** that left the old pump on there when upgrading to the in-tank pump, or is this a common practice? Doesn't make sense to me to leave the old one on there. When mine was upgraded, the old one was removed.
Old Mar 3, 2008 | 02:43 PM
Mayfair's Avatar
Mayfair
Default RE: Carter Fuel Pump Problem
Sounds like someone did the install the wrong way for sure. I never heard of it being installed that way.
Are you converting him over to your dual pump setup system now or what?
Old Mar 3, 2008 | 07:13 PM
Drew's Avatar
Drew
sounds like the dealership didnt know what they were doing. . .with the setup like it is I'm amazed the thing ran at all.
