damn auto lock/unlock
Old Mar 14, 2008 | 01:59 AM
Mayfair's Avatar
Mayfair
Default RE: damn auto lock/unlock
I have a similar problem, but i don't think it's the same
With the truck running, when I get out of it and go around to the passenger side, the door is locked. I have to run back around to the drivers door to unlock it. [:@]
When I turn the truck off though, all doors unlock, so I don't think it's the same problem as Woli.
Old Mar 14, 2008 | 07:15 AM
woligator's Avatar
woligator
yeah mayfair its the same but even when the truck is off the passenger stay locked
thx jake ill try that this morning
Old Mar 14, 2008 | 09:05 AM
12valveman's Avatar
12valveman
hey mayfair you have to disable the rolling locks on your truck other wise there is no way to unlock the truck door when you put it into park the only way your drivers door is unlocked is because you lifted the inside handle to leave. wish we hadthe same feature as the chevys that when you put it into park it unlocks the doors
Old Mar 14, 2008 | 11:19 AM
Mayfair's Avatar
Mayfair
I think you are right 12v.
I thought about it some more as I was trying to fall asleep ( Thank you very much !! [:@]) and I realized that yeah, my door probably WAS locked but I didn't realize it because it unlocks itself when I get out. When I roll up to pick someone up ( with the truck still running ), I have to unlock their door every time.
Old Mar 14, 2008 | 05:18 PM
Scott91370's Avatar
Scott91370
Mine works like Mayfair's. When I get to 15mph both doors lock. When I stop/shut off the truck nothing happens. I like it that way instead of any of the doors unlocking.
Nickolette mentioned the locking when the key is turned forward. My doors won't lock if the key is in the ignition. (BTW, I likeyour avitar!!)
Old Mar 14, 2008 | 07:20 PM
we_the_unforgiven's Avatar
we_the_unforgiven
It's a safety feature so somebody can't come mug you at a stoplight. I deactivated mine the day I picked it up. Always a pain because you never remember to unlock before you get out and try to open the passenger side. The guys that have 03 & newer can also program their remote transmitter to unlock all four doors when you press the button instead of just the drivers door.
Old Mar 14, 2008 | 08:36 PM
woligator's Avatar
woligator
work nicely for the seatbelts thanks now that chime is off when im only backing up the truck...
as for the doors jake its work nicely too but once i started stopped the truck a couple time later in the day it was back so i did it again and it was back later
worked for a couple restart each time though...maybe its interfering whit my remote start who control door lock too....
Old Mar 14, 2008 | 08:54 PM
01blkdually's Avatar
01blkdually
ORIGINAL: jakebrake
yeah press the unlock switch on the door as you get out
Dude, dont say stuff like that when I'm taking a drink of my soda.
Old Mar 16, 2008 | 02:17 AM
justviper1's Avatar
justviper1
woli you will probably have to change the settings on your remote starter to get it to stop locking like that. most-likely the bcm and theremote starter are fighting and when youshut the feature offin the bcm then the remote starter still does it. when i bought my truck the auto lock was on and i hated it. fortunately since my dad used to be a jeep dealer he still has the DRBIII so i was able to disable the lock feature and enable the horn chirp when the doors lock with the key fob.
Old Mar 16, 2008 | 08:04 AM
woligator's Avatar
woligator
yup ur right
