O.T. Kevin is the Man
Old Mar 16, 2008 | 10:43 AM
JimmyDiablo's Avatar
JimmyDiablo
Default O.T. Kevin is the Man
Kevin came over yesterday and hooked me up. My home was a model home built by richmond American and my garage was used as there office. Well for some strange reason I had only one 110 volt double plug in there on the south wall, and one on the cileling which was for the garage door opener. for almost three years I had a extension cord going to a multi outlet 6 and ran everything off of that. Kevin came and added 2 sets of two 20 amp gdi's near my tool box and work area. one on the ceiling with a switch for my flourescent lights and one outside for my holiday decorating lights.
Thanks Kevin.
Old Mar 16, 2008 | 11:49 AM
Kev_n_AZ's Avatar
Kev_n_AZ
Default RE: O.T. Kevin is the Man
your very welcome Yimmy!
turned a single light switch for the garage into a 3-way operable from gargae or inside house
added 2 dedicated 20amp gfci's inside the garage
extended the lighting circuit in the garage from the house door to the middle of the garage for better lighting capability
dropped a 20 amp dedicated gfci below the panel outside for lights, tools, power washer, etc....
Old Mar 16, 2008 | 01:51 PM
nickcoletti's Avatar
nickcoletti
are you going to need directions to my house kev?
Old Mar 16, 2008 | 02:47 PM
Jr. Mechanic's Avatar
Jr. Mechanic
Sounds like you did everything about as beefy as possible kev., you really sound like you know what you are doing, more than I can say for most professionals/handymen.
Old Mar 16, 2008 | 03:13 PM
Kev_n_AZ's Avatar
Kev_n_AZ
thanks guys!!
if yall pay for the fuel or plane ticket, I will gladly travel the country and do work for y'all!
right now I have a skid loader in my back yard to regrade a bit
http://upload.wikimedia.org/wikipedi...ehl_1640_l.jpg
Old Mar 16, 2008 | 03:21 PM
07FX4Chick's Avatar
07FX4Chick
ORIGINAL: Kev_n_AZ
thanks guys!!
Here ya go Kevin......
Old Mar 16, 2008 | 08:09 PM
BrianSudokhoi02's Avatar
BrianSudokhoi02
ORIGINAL: 07FX4Chick
ORIGINAL: Kev_n_AZ
thanks guys!!
You aren't going to do any "grading" with that little toy. We have NH170's at work and I hate grading with them because they are too small. Ours are ATLEAST twice the size of the one in the pic.
Old Mar 16, 2008 | 08:56 PM
Kev_n_AZ's Avatar
Kev_n_AZ
for my 1/3 acre, its enough
Old Mar 16, 2008 | 08:59 PM
Jr. Mechanic
Just curious, for the wiring, did you run 12/2 romex for those 20 amp circuits or are you guys required to run greenfield and conduit with THHN?
Old Mar 16, 2008 | 09:35 PM
Kev_n_AZ's Avatar
Kev_n_AZ
ORIGINAL: Jr. Mechanic
actually, I ran 12/3 romex for the 2 gfi's. they are in the same 2 gang box , so it was easier.
out here, all residential is romex (unless otherwise specified).
commercial is conduit..emt, imc, rigid, and even some m/c cable
