Fog Lamp Install Help
Old Mar 27, 2008 | 08:48 PM
SC Willie's Avatar
SC Willie
Default Fog Lamp Install Help
I ordered an EOM Fog Light package for my 2006 Dodge CTD 4x4 Quad Cab.
Can I tie them into the park lamps behind the head lamp assemblies?
How would you recommend to install them I want them all when the park lamp or head lights are on high or low beams?
The wire kit has a voilet colored wire that ties ito the low beams.....can I delete this wire if I use the cab mounted power switch?
Thanks!
Old Mar 28, 2008 | 12:47 AM
dirtydodge02's Avatar
dirtydodge02
Default RE: Fog Lamp Install Help
I'd recommend you just plug them into the factory plug-in that's behind the front bumper, just below the headlight on the driver's side. You said "package" so I assume it has the factory headlight w/foglight switch, which will plug in right where your current light switch is.
Old Mar 28, 2008 | 09:59 AM
mopar1973man's Avatar
mopar1973man
Stock is boring and only work on low beams... You might want to look at how I hooked up 4 - 100 watt aircraft landing lights... I got High and low beam sets... I even got a set for back up lights... Really easy to setup...
Fog light setup
http://mopar.mopar1973man.com/2002%2.../fog_lamps.htm
And the back up light setup
http://mopar.mopar1973man.com/2002%2...kup_lights.htm
Old Mar 29, 2008 | 03:51 PM
dirtydodge02
That could be fun. What'd that setup cost?
Old Mar 29, 2008 | 07:18 PM
mopar1973man
ORIGINAL: dirtydodge02
I can't remember what I paid to build them...I built two of them (2002 Dodge and 1996 Dodge) and love it.
(4) NAPA 4509 Spot Aircraft
(4) Rubber TractorBulbBuckets (normally outfited with 35 Watt bulbs)
(2) Relays
(1) Toggle Switch
14 Gauge Wire (I used bulk extension cord)
On low beam the fog light are brighter than the headlight on the truck. But on high beam I can see nearly a full 1/2 mile down the road light it was daylight. Great for keeping an eye on the darn deer that like to feed along the highway... I've got to replace 2 relays they got water in them and rusted... OPPS! Remember to get mountable relays and mount them to the fender...
You might want to look at this too...
Multi-funtion stick
http://mopar.mopar1973man.com/2002%2...ulti-stick.htm
Or... The overhead switch console...
http://mopar.mopar1973man.com/2002%2.../ohconsole.htm
Old Mar 29, 2008 | 07:27 PM
SC Willie's Avatar
SC Willie
Got'em done last night. They work great I rewired just alittle so they will stay on with the High Beams. Looks like a factory job. Thanks for you input!!
Old Mar 29, 2008 | 08:02 PM
dirtydodge02
ORIGINAL: mopar1973man
Multi-funtion stick
Both of those look great. Only trouble is, I have an Auto and a Lie-O-Meter
