Injectors have been pulled...
#21
RE: Injectors have been pulled...
ORIGINAL: mopar1973man
MMO is solvent based... Here if you want you can buy the raw materials at your local hardware storeand make it yourself... Here is the MSDS sheet for the materials...
http://mopar.mopar1973man.com/2002%2...DS%20Links.htm
Seriously there isn't many fuel additive that improve the lubricity of the fuel (as seen in the table above) other than BIO or OIL's. So any ASHLESS 2 cycle oil is fine. If you want to improve your anti-gel get snowmobile oil its got a much lower pour point than most diesel fuel (-40*F to -50*F).
If you want a lot of good reading head over to my 2 cycle oil page...
http://mopar.mopar1973man.com/2002%2..._cycle_oil.htm
ORIGINAL: 04QC4X4
If I read that chart right, then the MMO that I've been running is not a good thing. I thought alot of guys were running this. I run 8 oz of PSD with 4 oz of MMO per fill up which is usually 26-30 gallons. Should I switch to 2-stroke instead? What kind should I run?
#22
ORIGINAL: 04QC4X4
So you are suggesting that it is probably better just to run 2-cylce oil instead of PSD and MMO. I definetely don't want to damage my engine or fuel system. I'm open to any suggestions. I have noticed since I've been running the addatives that my engine runs a little smoother, but no increase in fuel mileage (and my mileage sucks, only about 14 mpg).
High cetane fuel tend to be lower in BTU's like winterized fuel tend always net lower MPG's because it 45> Cetane level. But why is this???
Now if you look at the BTU's of the chemicals added to the fuel to increase the cetane level you find everytime they are add products that are less than 20,000 BTU's by volume when diesel is 147,000 BTU's... Naptha (Zippo Lighter fluid or coleman fuel), Xylene (paint thinner), mineral spirits (paint thinner), napthalene (mothballs)...
Here is my BTU's listing...
http://mopar.mopar1973man.com/2002%2...2002%20CTD.htm
Chemical definitions...
http://mopar.mopar1973man.com/2002%2.../chemicals.htm
Here is the MSDS sheet on some fuels...
#24
#25
ORIGINAL: 02cummins
alright, i have the 2002 cummins, with the vp44 and a FASS 150 pump system, i guess all i wanna know is what do i asdd to my tank, and how much of it, how often? haha i dont wanna read all the posts on here
For a 3rd Gen truck 2003-2007 the best mixture rate is 256:1 which is 1 ounce of oil for every 2 gallons (256 Ozs)of fuel.
I use it summer or winter every time I get fuel I add a shot...
#27
#28
ORIGINAL: 04QC4X4
Thanks for all the good info moparman. Is there any type of 2-cylce oil that I should avoid or is it all the same?
Could you please explain why the difference in mix ratios between the 2nd and 3rd gen CTD's?
Check this out...
http://mopar.mopar1973man.com/2002%2...ilure_faqs.htm
#29
That page is full of good information. I really like the ScanGauge II, but they don't work on the 2004.5. I'm definetly going to stop using MMO and PSD and start using a 256:1 mixture of 2-cylce oil.
#30
I read a lot of moparmans threads over at cumminsforum and there was a ton of info on it. I have been using super syn for about 7 k miles and the engine is quieter. I couldnt tell a big difference in mileage, but if it helps to protect the VP44 from the ULSD, I'm all for it.
