FUEL!
Old Apr 8, 2008 | 12:25 PM
dodgemh123's Avatar
dodgemh123
Default FUEL!
HI,
Ihave a dodgecummings diesel 1994, sometimes when im drivng along its seems to run out of fuel, but then will kick back on.( i have fuel)lose of throttle response while driving, but then return. While this is happeing at red lights will stall like out of fuel, but then start right back up. Starting to increass more and more. It takes the engine to warm up for this to happen though. Any thoughts to what it could be?
Old Apr 8, 2008 | 01:32 PM
Mayfair's Avatar
Mayfair
Default RE: FUEL!
Bad fuel pump?
Water in fuel?
Dirty fuel filter?
Clogged air filter?
Old Apr 8, 2008 | 02:12 PM
steve05ram360's Avatar
steve05ram360
Default RE: FUEL!
tps sensor?? fuel pump failing when hot?/warm?
Old Apr 8, 2008 | 03:00 PM
RamItOne's Avatar
RamItOne
Default RE: FUEL!
on my first mercedes 77 300D i had that issue when I'd come to a light, I'd have to give it gas just so it wouldn't crap out.
Anyways my car had a prelim fuel filter, and that needed to be replaced.
Old Apr 8, 2008 | 03:25 PM
dodgemh123's Avatar
dodgemh123
Default RE: FUEL!
ORIGINAL: steve05ram360
yeah the truck has to be running around 30 mins or so for this to start, so if it was the fuel pump, wouldn't it happen all the time? the engine temp is norm. then when i hit the gas sometimes it delays and there is a ping on the drivers side, then it kicks in and gives power back. But cold engine plenty of power and no problem....
Old Apr 8, 2008 | 03:30 PM
Mayfair's Avatar
Mayfair
Default RE: FUEL!
Unfortunately I don't know much about the 12 valve 1st gens. Guy's who do are kinda scarce these days, however Kev still has his. Hopelully he'll chime in soon.
Old Apr 8, 2008 | 09:44 PM
mopar1973man's Avatar
mopar1973man
Default RE: FUEL!
Check the wiring to the VE pump. There is one wire that controls the shut down solinoid for shutting down the engine. If the wire happens to be loose or damaged it would cause the pump to shut down the fuel...
Old Apr 8, 2008 | 10:06 PM
Drew's Avatar
Drew
Default RE: FUEL!
I thought 94's were the first year for the P7100's.
sounds like the fuel shutoff solenoid is going out.
Old Apr 9, 2008 | 01:18 AM
dodgemh123's Avatar
dodgemh123
Default RE: FUEL!
ORIGINAL: Drew
yeah thats what i think from what i read. i just wish i knew before i spend all this money, well the shutoff solenoid is cheap. But hey! money is money now days. Thank you for all your help. any more help would be awesome.
thanks guys!
Old Apr 9, 2008 | 02:56 PM
lockman's Avatar
lockman
Junior Member
Default RE: FUEL!
I had the same type of problem with my 2002. I changed the fuel filter and air filter. While I was at it, I added a duel fuel filter on the frame.
I've had no problems since except my fuel guage works only when it wants to.[:'(]All the guages work fine except that one. Anyone have any ideas about that?
Lockman
