what kind of differential fluid??
Old Apr 8, 2008 | 10:43 PM
t_stone85's Avatar
t_stone85
Default what kind of differential fluid??
ok so im gonna change my front and rear differential fluid, as well as the tranny....so what kind of diff fluid do i need to put in i have a 2wd its a dana 80 (hyb)....and also im going to get castrol syntorq for my tranny but im getting mixed info.... the stuff im about to order is the Castrol Syntorq® LT 75w85w full synthetic gear oil ..well my ? is on some other sites they say Castrol Syntorq 75w90??? so i dunno which one to use.....im pretty sure its the 85 but a second opinion is allways helpful......
anyone no how to get another owners manual?
Old Apr 8, 2008 | 10:47 PM
Drew's Avatar
Drew
Default RE: what kind of differential fluid??
what year truck and what's the tranny.
RamItOne's Avatar
RamItOne
amsoil 75 90 severe gear...
heres a link for owners mans
https://techauthority.gltghosting.co...atalogId=10051
Old Apr 8, 2008 | 10:53 PM
73Jim's Avatar
73Jim
Which is it? Front and rear diffs mean a four wheel drive, yet later you say it's a 2wd. Either way, it depends on what you use the truck for. 75 90is good for the front axle andthat would be as light as I would go in the rear; only if you don't tow or haul anything heavy. 75 140 in the back if you tow/haul frequently. Or somewhere in the middle, again it depends on how and where you use your truck.
Old Apr 9, 2008 | 08:26 PM
t_stone85's Avatar
t_stone85
the tranny is the nv4500... and as for the DIFF. itow a fifth wheel for work so i i will be towing.
Old Apr 9, 2008 | 08:40 PM
Drew's Avatar
Drew
the NV4500 takes 8.5 pints of 75-90 syntorque.
if you tow alot I would suggest going with either a 75-110 for moderate towing, or 75-140 if you tow heavy. just make sure you add about 8oz of friction modifyer before adding fluid if you have a limited slip rear. and you'll ne a bit over a gallon of fluid.
Old Apr 10, 2008 | 01:12 AM
t_stone85's Avatar
t_stone85
so not the 75w85w cus on this website http://quad4x4.com/NV4500%20Parts.htm(scroll down and youll see the oil) they say use the 75......in any instance is this just as good or better than then the $22.00 a quart mopar that the dealerships gives uyou?
friction modifyer?? is that regardless of what kind of lube you put in?
Old Apr 10, 2008 | 06:54 AM
Drew's Avatar
Drew
I dont think I labeled things properly for ya looking back on my post. . .the tranny needs the 75-90 syntorque, and axels need 75-90, 110, or 140 with the friction modifyer if you have a limited slip.
