Ughhhh!
Old Apr 15, 2008 | 09:54 PM
campermama's Avatar
campermama
Default Ughhhh!
Ok so the probe is in and now seems to be the easy part!
For the Pyrometer.....
Where do I connect the red pyrometer wire to the ignition? And the negative also?
Where do I get the wire to connet to the blade connectors on back of gauge?
The boost...
I cannot find what bolt to replace with the boost bolt
The tubing does not stay in the bolt even after tightening
I have no good instructions for hooking this gauge up
Can somebody please help? I am outside trying to get this done now. Thanks!!
Old Apr 15, 2008 | 09:57 PM
firemedic740's Avatar
firemedic740
Default RE: Ughhhh!
what is the isspro model number on the pyro?
Old Apr 15, 2008 | 10:00 PM
campermama's Avatar
campermama
Default RE: Ughhhh!
3707G and boost is R6723
Old Apr 15, 2008 | 10:05 PM
campermama's Avatar
campermama
Default RE: Ughhhh!
I also have like 10 feet of lead wire high temp, red and yellow, what do I do with that? I can't believe there are like no instructions with this!
Old Apr 15, 2008 | 10:11 PM
firemedic740
Default RE: Ughhhh!
The red wire needs to go to a ignition positive, so if you have a test light find one of the wires that gets hot when you turn the ign. on, I think a thicker orange or yellow wire, and the negative just needs to be grounded to something. Try this- sure you already have it though.
http://www.isspro.com/installation/IS026.pdf
Old Apr 15, 2008 | 10:13 PM
campermama's Avatar
campermama
Default RE: Ughhhh!
I know that I just don't know where? And I have no idea where to get the wires through the fire wall since my truck is a stick and instructions are for an automatic to use the clutch hole.
Old Apr 15, 2008 | 11:33 PM
dirtydodge02's Avatar
dirtydodge02
Default RE: Ughhhh!
Sounds like a PITA to me... I tried Googleing it under Images, but got nothing. Maybe I'm not trying hard enough...
Old Apr 15, 2008 | 11:53 PM
gtxpooch's Avatar
gtxpooch
Default RE: Ughhhh!
I used the hole where the E-brake goes through the firewall to hook up the Edge. Also you should be able to hook into the fuse block using a fuse block adapter, not which one on an 04
Old Apr 16, 2008 | 01:26 AM
Mayfair's Avatar
Mayfair
Default RE: Ughhhh!
I know you have a newer truck than mine, but this is where I ran my wires through the firewall. It's on the drivers side.
