how the hell....
RE: how the hell....
Hoo mayfair ur asking for troubles
the plate that bolt to the fass itself broke in half right in the middle were the 2 top bolts are connected
the L Brace still hold
ive take a 4'x 3/8 plate this time whit corresponding hi grade bolts
[IMG]local://upfiles/67050/5F37AFF3F25940C8B0A1C1C45CD21EF8.jpg[/IMG]
Woli and Donny, or anyone else with one, what all has your FASS done for your trucks? What kind of flow rate would you recommend for someone with as many mods as I plan to have (Edge, Smarty, Intake as far as things that will affect the fuel system) I was looking at the prices on these and damn! $650-750!! Good God!!
ORIGINAL: dirtydodge02
Now try giving Airdog a try...
http://www.pureflowtechnologies.com/
It the same darn pump but at lower prices... I've got mine coiming today for $500
As for my current fuel demands is about 30-40 GPH (@WOT) total with all my Bombs I've got... So AirDog's 150 GPH pump should be more than enough for me... I was considering the AirTex or Stock but after going through 4 stock styled pump I lost my faith in them.
I'm still not sure how it is that you had it mounted in the first place. This is how FASS wanted it mounted
And this is how you did your install
Did you drill new holes in the bracket and use it upside down or something?
Dirty - The FASS is just a realy good lift pump that will provide a good constant fuel pressure. It's very well made and has stood the test of time. Yeah, it's expensive, I agree 100%, but I think it's worth it. If I needed another lift pump tomorrow, I'd buy it again.
Dirty, the FASS / Airdog battle is pretty much the same as the Chevy / Ford or Dodge battle. You're gonna get a bunch of different reasons why one is better than the other and most of the time people will fight to the death to prove why they made the right choice. I chose the FASS at the time simply because at the time I could get filters anywhere, and their customer support is second to none - it still is !!
Here's a video for you to watch:
http://www.fassride.com/fass-brands-video.html
