my truck is a crack whore !!!
Old Apr 17, 2008 | 08:41 PM
Kev_n_AZ's Avatar
Kev_n_AZ
Default my truck is a crack ***** !!!
I messed up guys. when i had the vegi oil malfunction, i used starting fluid. now the truck is refusing to start with out the starting fluid at random times. even after driving 50 miles.
any ideas ???????????????
Old Apr 17, 2008 | 08:44 PM
JimmyDiablo's Avatar
JimmyDiablo
Default RE: my truck is a crack ***** !!!
Group hug
Old Apr 17, 2008 | 08:45 PM
NickBeek's Avatar
NickBeek
Air trapped somewhere in the system. Some one should be able to tell you how to properly bleed it. Also how's your lift pump?
Old Apr 17, 2008 | 08:46 PM
Kev_n_AZ's Avatar
Kev_n_AZ
remember , this is a 93 1st gen 12valve.
my lift pump is new.
I may try a fuel filter friday after I get paid.
Old Apr 17, 2008 | 08:57 PM
JimmyDiablo
You can try a trade in. Contact Dave at James O'Neal Dodge. Bremen GA.----- 1-800-663-2522 www.onealdodge.com He will take good care of you
Old Apr 17, 2008 | 09:00 PM
Kev_n_AZ's Avatar
Kev_n_AZ
lmao @ Yimmy!!!!
Old Apr 17, 2008 | 09:01 PM
RamItOne's Avatar
RamItOne
ORIGINAL: Kev_n_AZ
put it to work and earn its diesel then...
dirtydodge02's Avatar
dirtydodge02
Maybe rehab or a 12-step program?
Old Apr 17, 2008 | 09:22 PM
Drew's Avatar
Drew
kevin kevin kevin. . . .
try bleeding out your injector lines
Old Apr 17, 2008 | 09:58 PM
Kev_n_AZ's Avatar
Kev_n_AZ
I cracked the lines a few weeks ago.
I will change fuel filter and bleed whole system down again this weekend......
it was mentioned that starting fluid is like crack to a diesel. it becomes dependant upon it.
