double disk clucth
Old 05-08-2008, 03:51 PM
finny's Avatar
finny
finny is offline
Default double disk clucth
how would you know if a truck has one? supposedly my dad says he has one in his 96 3500 (possible my future truck) but i dont think it does and i need to prove it too him,
Old 05-10-2008, 03:00 AM
finny's Avatar
finny
finny is offline
Default RE: double disk clucth
no one?
Old 05-10-2008, 04:25 AM
jeff B's Avatar
jeff B
jeff B is offline
I have the Southbend 3600 DD withe the upgradedhydros, and still anyone that I let drive my truck says ,now thats a heavy clutch to push in.
Old 05-10-2008, 05:53 AM
cumminalong's Avatar
cumminalong
cumminalong is offline
Well, unless you actually take it out and look, it's gonna be a bit difficult to tell.
Does the manual have an inspection plate in the bell housing?
If it does, you could just pop the plate and take a look.
Old 05-10-2008, 02:14 PM
finny's Avatar
finny
finny is offline
i will have to check. the clutch is very heavy. but thats because i am comparing it to a mitsibishi lancer
Old 05-10-2008, 10:13 PM
jakebrake's Avatar
jakebrake
jakebrake is offline
Not sure if the inspection cover will give you a good enough view. If ya really want to know you could pull the starter and look in there with a mirror.
Old 05-10-2008, 10:35 PM
Drew's Avatar
Drew
Drew is offline
only way to truly tell is either what Jake said, or pull the tranny. that will realy tell you if you have a DD.
I have upgraded the hydraulics on my yoda, and the pedal pressure is still no where near what stock is on the ram. and that is with a higher plate load clutch for the yoda.
Old 05-11-2008, 11:29 AM
finny's Avatar
finny
finny is offline
well i havent physicly checked but my dad brother and two of there friends (who put it in) claim they put in a centerforce dual disk clutch in.
Old 05-11-2008, 06:06 PM
Az2500Cummins08's Avatar
Az2500Cummins08
Az2500Cummins08 is offline
Well I guess theres your answer. Unless they have reason to tell you otherwise.
Old 05-11-2008, 09:01 PM
Drew's Avatar
Drew
Drew is offline
centerforce has dual disk clutches???????
that I didnt know. . .I just looked their website over and couldnt find anything. now they could ahve made them a while back, but the only DD manufacturers are South Bend and Valair.
Quick Reply: double disk clucth
