01 2500 diesel load
Old May 11, 2008 | 11:58 PM
justviper1's Avatar
justviper1
Default RE: 01 2500 diesel load
i had the edge ez on my truck before i went with the adrenaline. it is only rated at around 40-60 hp i believe. it seemed to work good! i would consider sellin you mine since i don't use it anymore!
Old May 12, 2008 | 06:46 AM
cumminalong's Avatar
cumminalong
You definitely won't want to crank up the power while you are towing, unless you've done some decent intake mods (i.e. aftermarket intake, intercooler, manifold) and opened up the exhaust. Otherwise, it's gonna build heat fast on the hills. Extra fuel needs extra air to keep the temps in check.
I don't turn my Edge up past 2 while towing even 8 - 9K. On the hills, you can see the temps come up quick any higher than that.
Besides, the stock tranny will take a beating if you turn it up more than that.
