WINspeed heater grid delete ??????
Old May 12, 2008 | 09:51 PM
NickBeek's Avatar
NickBeek
Default RE: WINspeed heater grid delete ??????
Someone get me a drawing with dimensions and tolerances and I'll have one made. If there is not a patent then I'll get a production run set up if need be.
Old May 12, 2008 | 10:02 PM
steve05ram360's Avatar
steve05ram360
thanks for the link... their testing goes right along with my butt dyno, nice gains down low. According to the dyno charts... the CFM looks to really kick *** down below the 1900 rpm mark, not enough though to make me switch with that manifold on, where do you tap for the boost gauge?
Old May 12, 2008 | 10:15 PM
htgriffith's Avatar
htgriffith
Steve, You can buy them with or with out ports.
Nickbeek, I do not know if some one has a patent on then or not, As far as getting the specs on one I guess all you would have to do is pull yours off and spec it out.
Old May 13, 2008 | 01:44 PM
DBLR's Avatar
DBLR
What I have read about the grid delete that unless your making big HP/TQ numbers leaving the grid heater in will not affect your performance very much.
Old May 13, 2008 | 05:48 PM
Mayfair's Avatar
Mayfair
GREAT !!!
NOW I want a grid delete thingy !!
THANKS Griff !!
Old May 13, 2008 | 05:54 PM
bigoilwhore's Avatar
bigoilwhore
http://www.glacierdieselpower.com/pr...pf_id=98507-PF
Glacier Diesel has them for 59$.
Old May 13, 2008 | 06:13 PM
buckskin's Avatar
buckskin
Mine has to stay in, If I took it out I could only use my truck about 3 months out of the year still in the mid forties at night.
Old May 13, 2008 | 07:45 PM
htgriffith's Avatar
htgriffith
bigoilwhore, Thanks for the link.
Old May 13, 2008 | 08:39 PM
htgriffith's Avatar
htgriffith
buckskin, My 2 cents on that is.
The grid heaters are there primarily for emissions reasons, the EPA cold start cycle.
They don't do anything for starting when the weather is cold. a 17.1:1 compression ratio will cook the air more than a silly little grid heater. the grid heater is like holding a candle in the wind, and trying to heat a ball park.
Old May 14, 2008 | 07:51 AM
CowboyBob's Avatar
CowboyBob
well here in winter we NEED this grid else truck wont start at all
Without the heater grid, you could use starting fluid and your truck won't explode.
