Lamp out indicator
Old May 14, 2008 | 08:42 PM
handymanherb's Avatar
handymanherb
Default Lamp out indicator
On the way home today I got a lamp out light come on, according to the 05 manual it come on when a headlight is out or a wiring problem, but every lamp is lit, do i need to start unplugging connectors and plugging them back in or what.
Thanks ahead of time to all who know more than I, but then that's a long list LOL
Old May 14, 2008 | 09:04 PM
Drew's Avatar
Drew
Default RE: Lamp out indicator
when the resistance gets too high it will trigger the lamp out indicator. anything from dielectric grease, to replacing the bulbs, to even replacing the assembly has fixed the problem
Old May 14, 2008 | 09:22 PM
handymanherb
Is it just the head lights or all lights, sounds like it can be fun to find
Old May 14, 2008 | 09:25 PM
SpLaT's Avatar
SpLaT
Handymanherb, start with the tail light assemblies, number of Ram owners having issues with the "lamp out". The tail light "bar" leaves a lot to be desired,check bulb conditions and sockets. Make sure you do have brake lights as well as single each side and third brake light. Good luck.
Old May 14, 2008 | 10:08 PM
handymanherb
Brake light out right side hit the flashers thought that would tell me if it was out, but brakes lights are different on the new trucks, so I used a broom to set the brakes and found it .
Now to get it replaced, but I still have 2 burning anyway.
Manual was no help, said it only applied to headlight system, so that's why I didn't check the brake lights before, I had every thing else on but the brakes. so thanks Splat and Drew
Old May 15, 2008 | 10:30 AM
JimmyDiablo's Avatar
JimmyDiablo
on Diablo, same issue, it was a brake light... guess I dont have to worry about that anymore do I?
Old May 15, 2008 | 10:40 AM
handymanherb
ORIGINAL: JimmyDiablo
And we all here feel, your pain man, Sorry you had to give it up, but hang in there and know it does get better.
