Tapping for EGT sensor
Ok, I FINALLY got a tap for the EGT sensor... Thing is, the manual doesn't say what threads per inch to use. I bought a 1/8" NPT with 27 threads per inch. Is this the right one? I'm not gonna take the drill to it until I know for sure. Any insight would be greatly appricated!
1/8"NPTF with a R(0.339) drill bit
1/4"NPTF with a 7/16" drill bit
Important must use NPTF = national pipe thread FINE
you can also see if the threads of the bushing match with those of the tap see if they match, by laying one on the other.
On my ISSPRO gauges it isa 1/8" 27 tpi npt. Are you going to remove the turbo? I just loosened the four bolts enough to slide a pieceof a minilla folder through. When I was done drilling and tapping I used a shop vac to clean the area and wha la, no shaving in the turbo.
[IMG]local://upfiles/54996/9495117517FC4AC2AFF091A11240C500.jpg[/IMG]
Tap I got is stamped the same as yours Chewy, so I guess I'll get 'er done. Thanks for the help guys. And that's a really good idea Jim. Might have to do that.
Trending Topics
Here is a nice wrote up and what I used for a reference.
http://www.dieselmanor.com/diy/CMS3-...ugeinstall.htm
It took me a while longer to drill mine out doing it the way they reccommed with starting with a TINY drill bit and going a few thousandths at a time. But the only thing you literally get out is DUST, no big shavings or anything like that. No I did not remove the turbo.
ORIGINAL: Twoforme2
That's also a great idea with the manilla slid in Jim !!
Now I KNOW I did a write up for this.....with lots of pics.....lots of different things you can do......etc.
Oh, here it is......up in the DIY Sticky!
Drillingand tapping for EGT probe
