AFE Stage II & CFM+ Install and First Impressions
I have the same AFE intake and I love it even though it is a bit loud. My roomate came out and ask what that was, of course this was after i got it put in and was seeing how well it work. between my intake and my magana flow exhaust i may need hearing aids soon lol. i love it.
The Edge has several alarms that you can manually set.
There are alarms for boost, EGT, tranny temp, engine temp and a speed alarm.
You set them for whatever value you choose and the screen flashes and sounds an audible alarm when the value is reached.
Normally, you set the alarm a bit lower than the point you set the Edge to defuel, so it alerts you when you're approaching the value you entered.
Example:
If you want it to defuel at 40 psi, you set the alarm for 36 and it gets your attention when it hits 36 psi.
Example:
