Quick Pyrometer Question
Old Jun 13, 2008 | 02:56 PM
Loydt's Avatar
Loydt
Default Quick Pyrometer Question
Ok, got it installed per the instructions I found on here (Thanks!!). It is installed BEFORE the turbo in the exhaust manifold.
My question is, how hot is considered too hot? I am all stock with the exception of a superchips programmer set in "tow" mode. I leave in two weeks for a cross country trip to Wyoming and the Tetons towing a 38' 5th wheel.
Old Jun 13, 2008 | 03:14 PM
Ruggedroast's Avatar
Ruggedroast
Default RE: Quick Pyrometer Question
To the best of my knowledge you don't want anymore than 1200 degrees for any kind of extended period. I'm sure the heavy hitters on here will give you all the detail soon enough.
Old Jun 13, 2008 | 03:48 PM
RamItOne's Avatar
RamItOne
1200 seems to be the general consensus here.
I know a ferd guy with a banks six gun that hits 2,200f
Old Jun 13, 2008 | 04:00 PM
cumminalong's Avatar
cumminalong
1250 is the safe limit. You can run that all day long with no ill effects.
Short bursts into the 1350 range are okay, but not for sustained running.
Old Jun 13, 2008 | 05:09 PM
cumminalong
ORIGINAL: RamItOne
He might have done it once.
Old Jun 13, 2008 | 05:34 PM
tiresmoketravis's Avatar
tiresmoketravis
can one go bad mine jumps all over place on occasions
Old Jun 13, 2008 | 05:40 PM
cumminalong
It could, not likelythough. They are pretty durable. What do mean by jumps all around?
Old Jun 13, 2008 | 05:43 PM
tiresmoketravis
it go from 8-6-10-4-15-3 just some random movements
Old Jun 13, 2008 | 05:52 PM
cumminalong
Is it an analog gauge or digital?
If its analog, I would say that more than likely it's the gauge, not the probe. Check your connections.
Old Jun 13, 2008 | 05:58 PM
cumminalong
The analogs work on a sweeper motor and, like any other electronic component, it can go bad.
