Dash Brake Light Flashes, What does it mean?
Old Jun 18, 2008 | 10:49 AM
dragonslayer169's Avatar
dragonslayer169
Default Dash Brake Light Flashes, What does it mean?
About 2 weeks ago my parking brake and abs light on my dash will light up for a second and there will be a bing and then it goes away. On a couple of instances the light has stayed on for a few minutes but it always just turns off. Does anyone know what this means? I have search all over the internet and haven't been able to find anything. I have checked for codes but there are none being put out. I have checked my brake fluid and it is almost at the full level.
Old Jun 18, 2008 | 10:50 AM
dragonslayer169
Default RE: Dash Brake Light Flashes, What does it mean?
When it happens its like the image in the following post
Old Jun 18, 2008 | 10:51 AM
dragonslayer169
dragonslayer169
any help would be greatly appreciated. Thanks, Steve
Old Jun 18, 2008 | 11:09 AM
Cumminnotstrokin's Avatar
Cumminnotstrokin
my 98.5 did that for a few weeks then it stayed on. It turned out to be the ABS sensor in the rear differential.
Old Jun 18, 2008 | 11:47 AM
dragonslayer169
cumminnotstrokin, did the sensor go bad and need replacing, or was it just loose? I never thought to check my abs sensors, but it did start after i went mudding and washed my truck. Maybe when i was hosing off the undercaraige(sp) it knocked one of my sensors loose.
Old Jun 18, 2008 | 07:42 PM
Cumminnotstrokin
The sensor was bad. it should only have one bolt on top of the pumpkin holding it in
Old Jun 19, 2008 | 11:20 AM
Scott91370's Avatar
Scott91370
The sensor is in the rear end, isn't it? It may just be loose.
Mine starting blinking one day on the way to work. Turned out while I was working under the dash I knocked the brake light switch loose and this caused it. It didn't cost a penny to fix- worth looking at.
Old Jun 19, 2008 | 12:37 PM
kdtlr's Avatar
kdtlr
I agree with cumminnostrokin, had the same thing happen to me. Supposably there are three of these speed sensors on our truck and they all need to match or else you get this light. When they don't match, they think the truck is slipping and trips the ABS. Replaced my right front and rear and went away.
Old Jun 19, 2008 | 11:11 PM
dragonslayer169
Awesome, thanks for the replys. i am going to go check the one on the back to see if it came loose or something.
