Installing pyrometer
Old Sep 8, 2008 | 05:08 PM
SmilingDon's Avatar
SmilingDon
Default Installing pyrometer
I have an 08 2500 with a 6.7 Cummins. I want to install a pyrometer ahead of the turbo. There is a threaded connection on the exhaust minifold that has a tube running to a sensor. Does anyone know if I can install a tee into the manifold to mount the thermocouple for the pyrometer and that tube running to a sensor at his point? I am hesitant to have to remove the manifold to drill and tap it (1/8 NPT). Thank you for your input!
Old Sep 10, 2008 | 10:58 PM
cmnspwr's Avatar
cmnspwr
You can drill and tap it without removing it. A buddy of mine that has a 6.7 said he took off his wheel to get a better angle on it.
Old Sep 11, 2008 | 12:50 PM
SmilingDon's Avatar
SmilingDon
I knew that I could drill and tap the mamifold in place, but I heard that if any of the chips got into the turbo, it could damage it.
Old Sep 15, 2008 | 08:08 PM
bekim's Avatar
bekim
A broken drill bit will damage it, or a broken tap. Drilling the last bit out with the engine running will blow the shavings out with the exhaust. This concern is common and frequently discussed, but problems are rare and always involve chunked bits or taps. Do a search on any of the Dodge diesel forum sites. There are MANY related posts.
Cheers
Mike
Old Sep 17, 2008 | 06:38 PM
campermama's Avatar
campermama
I drilled and tapped mine in place and used a telescoping magnet (bought at auto parts store for $2) and just kept stopping andsticking the magnet in there until it came out clean from shavings. Worked great!
Old Sep 17, 2008 | 09:02 PM
JDub06MegaC's Avatar
JDub06MegaC
Check out my post with pics showing my pyro/boost install with the overhead console. Just more options for you to look at. https://dodgeforum.com/forum/dodge-ram-diesel-tech/172190-06-boost-question.html
Old Sep 18, 2008 | 10:18 PM
joey7106's Avatar
joey7106
when you drill into the manifold put some grease on the bit. this will keep the shavings from entering the manifold.
