Warning horn when door is open
Old Nov 20, 2008 | 12:28 AM
Carl00723's Avatar
Carl00723
Default Warning horn when door is open
I hook up to a lot of trailers and when in "R" with the door open the horn sounds. Can this be eliminated. If so how? I have asked the delaer if they can reprogram it so that it doesn't do it but they say no.
Old Nov 20, 2008 | 10:55 AM
ZmanTRX4's Avatar
ZmanTRX4
It's because some tard fell out while backing a truck up a long time ago so now they make it do this. The dealership won't do anything about it, but I've heard of some guys splicing into the wire and putting a switch on it so that it won't do it anymore. I don't have much info other than that though. My 06 doesn't do it though thank God. I do this on a daily basis. I'll probably wish it did do it though when I fall out haha.
Old Nov 20, 2008 | 03:47 PM
Tally12V's Avatar
Tally12V
There is a sensor on the door. You could probably just jam the sensor closed so it always thinks the door is shut.
Old Nov 20, 2008 | 08:15 PM
BrianSudokhoi02's Avatar
BrianSudokhoi02
Buckling the seat-belt behind you will also make it not beep.
Old Nov 20, 2008 | 09:11 PM
thomas70's Avatar
thomas70
My 06 does it, a friend is a service manager at a dealership. He put the computer on it and tried to get it off but the computer won't let you do it. He did however turn off my seatbelt alarm.
Old Nov 20, 2008 | 09:28 PM
Parts/Service's Avatar
Parts/Service
You can also put the e-brake on ever so slightly.
Old Nov 20, 2008 | 10:03 PM
Carl00723's Avatar
Carl00723
Default Horn
Thanks for the input. I won't have to worry about it when I get the train horns hooked up I'll just disconnect the original one. Ha HA, there's always more than one way to blow your horn. Believe I can do that in about 3 years. $$$$$LOL
Old Nov 22, 2008 | 11:07 PM
Muddy's Avatar
Muddy
You disconnect the wire at the plug under the driver seat near where the seat belt bolts to the floor and jumper the two pins in the plug. This also disables your seat belt chime and indicator on the dash.
