I need more traction
Old Dec 3, 2008 | 12:14 PM
ezbassin's Avatar
ezbassin
Default I need more traction
I have a 2004 Ram with the cummings diesel with a tow package but do not have a limited spin differential. I pull a bass boat and on some ramps I need more traction than just from one wheel. I have 355 gears and a 11.5 rear end. What can I do to get both wheels to pull. I already have off road tires on the truck but need both wheels to pull going up the ramp.
What are my options?
Old Dec 3, 2008 | 12:38 PM
HammerZ71's Avatar
HammerZ71
I think you answered your own question. You need a LSD or maybe even a locker in the rear of that truck.
My truck came with an open diff and I had an issue, especially on the slick red clay ramps on some of the smaller waters in Ga. when I had my bass boat.
When I re-geared to the 4.56s for my larger 35" tires I added an Auburn Gear LSD, problem solved...
Old Dec 3, 2008 | 04:41 PM
Bass Hunter's Avatar
Bass Hunter
ARB also makes a locking diff that is actuated with a togle swithch. It's an open diff normally but when you hit the switch you have a spool. Open for the street fully locked when you need it, not good locked on the highway though.
Old Dec 3, 2008 | 04:58 PM
ezbassin's Avatar
ezbassin
Where is the best place to get the parts I need.
Old Dec 3, 2008 | 05:02 PM
Bass Hunter
usually you would have a off road shop or specialty shop do the install for you and they may want to provide the parts as well for waranty reasons. Diff work is not something you can do without the proper tools and training. Unless you are a mechanic or extremly able do it yourselfer it's not a do it yourself job.
Old Dec 4, 2008 | 01:20 AM
moconst's Avatar
moconst
Im assuming you have a 2wheel drive ?
Old Dec 4, 2008 | 01:24 AM
explrcnvrtbl's Avatar
explrcnvrtbl
if its a 4wd, toss it in 4wd, if you need more torque, throw it in lo range
Old Dec 4, 2008 | 07:01 PM
ezbassin's Avatar
ezbassin
It is 2WD
Old Dec 4, 2008 | 07:13 PM
explrcnvrtbl
might want to look into a traction aiding device such as a limited slip or a locker
there are old school tricks of getting the open diff to trick it under load to transfer power as well, might want to research that
