Elevated Boron in oil analysis
Old 01-08-2009, 10:01 AM
lesimon's Avatar
lesimon
lesimon is offline
Default Elevated Boron in oil analysis
Has anyone else noticed elevated Boron PPM in their oil analysis while using Shell, Rotella 15W40 conventional oil recently.
Sample 1) 1 ppm
2) 2 ppm
3) 4 ppm
4) 1 ppm
5) 1 ppm
6) 25 ppm
7) 27 ppm
After doing some research I found that this could indicate a coolant leak or it could also be an additive in the oil. Can anyone tell me if it is indeed an additive included in the oil.
Old 01-08-2009, 03:25 PM
SmilingDon's Avatar
SmilingDon
SmilingDon is offline
I don't know the answer to your question, but the company that did my oil analysis would indicate what the normal ranges were for a given element base on the engine and the brand of oil.
Old 01-08-2009, 05:57 PM
Joel_MD's Avatar
Joel_MD
Joel_MD is offline
Mine has never been higher than 3, using Amsoil DEO 5W-40. When yours jumped up to 25, was that the first analysis after you switched to Rotella?
Old 01-08-2009, 07:10 PM
bekim's Avatar
bekim
bekim is offline
Yes, I read that at the Faq on Blackstone Labs site some time back. Some labs include warnings if any readings seem abnormal. Did your report have any comments at all?
Mike
Old 01-08-2009, 08:47 PM
SpLaT's Avatar
SpLaT
SpLaT is offline
Boron is an detergent additive and a anitfreeze inhibitor (meaning it protects metal part from the anitfreeze to a point)
Some oil makers have increased the amount of Boron in their additive packages.
I would be more concerned with the amount of fuel, anitfreeze and/or water that might be showing up in the oil samples.
Other real concerns would be the wear indincators such as:
-Aluminum
-Chromium
-Iron
-Copper
-Lead
-Tin
-Molybdenum
-Nickle
-Maganese
-Silver
-Silicon
I wouldn't worry too much about the Boron, as there are a number of companies offering a boron additive packages for commerical and private users. As it has other then the antfeeze inhibiting property it also aids in coating the metals. Making things a little more "slippery".
Quick Reply: Elevated Boron in oil analysis
