tranny
Old Feb 1, 2009 | 04:50 PM
dave29989's Avatar
dave29989
Default tranny
i have a 2002 ctd 2500 auto when it is shifting into over drive it goes in out in out in out time for a flush and fill? or tranny? need help
Old Feb 1, 2009 | 09:10 PM
Parts/Service's Avatar
Parts/Service
I know this sounds crazy, but make sure all battery cable ends are clean and tight.
Old Feb 2, 2009 | 03:43 PM
dave29989's Avatar
dave29989
nothing sounds crazy at this point i will try anything to not have to replace the tranny
Old Feb 2, 2009 | 05:20 PM
transguy37's Avatar
transguy37
Hello,
This sounds like some kind of electrical problem. Really need to get a scanner on it and watch all the inputs and outputs. Could be anything from the trans relay out under the hood to a FIPL switch wich would be the same as a TPS on a gas model. One way to determine if it's OD or lock up going in and out, is when it starts doing it push the Od cancel button and see if rpm's go up. It's possible that it's lockup that's going in and out and not OD. Hope this helps.
Old Feb 10, 2009 | 09:30 PM
Jester52's Avatar
Jester52
Sounds like that stick thottle senser to me..
