2500 running hot
Old Mar 10, 2009 | 01:25 PM
logjam14's Avatar
logjam14
Default 2500 running hot
hay guys, I have a 03 2500 that's got over 200.000 on it,iv added a juice/w attitude, afe cold air intake packs brk and 3.5 inch free flow muffler, I'm having a hard time keeping the temp down it runs at 200 to 215 any ideas is appreciated
Old Mar 10, 2009 | 02:24 PM
lghtngblt02's Avatar
lghtngblt02
The RAM Administrator
Welcome to Df Log! Not too sure on your problem but I'll move your thread over to the 3rd Gen Ram Section for better input for ya. Enjoy the site
Old Mar 10, 2009 | 02:34 PM
HammerZ71's Avatar
HammerZ71
Sounds to me like a CTD, forgive old 'bolt, he don't know a diesel from a toaster oven!
I'm gonna put you in the CTD section for better responses...
Old Mar 10, 2009 | 03:04 PM
srountreeoo7's Avatar
srountreeoo7
Check your coolant level. Thermostat and water pump. I just had to replace my pump due to it leaking from the front. If it's not leaking then I would think about replacing the thermostat. just my .02 cents
Old Mar 10, 2009 | 05:14 PM
Scott91370's Avatar
Scott91370
As stated could be thermostat or coolant level. When mine ran warm it was the fan clutch.
Old Mar 10, 2009 | 07:12 PM
racer9's Avatar
racer9
Since you're in AZ and have lots of miles, I would flush out the exteral radiator fins with something like SimpleGreen. DO NOT USE a power washer, just a regular garden hose pressure is enough.
Check your breather catch bottle, it is probably gone, or full. Extend the drain hose a little farther back, just be sure there's no low spots in it.
What happens is the oil mist from the breather gets pulled into the radiator by the fan and then the oily fins start collecting dust, which slowly plugs the fins causing hot temps.
The other suggestions are also good things to look into.
Old Mar 11, 2009 | 10:47 AM
logjam14's Avatar
logjam14
Default running hot
hay all, thanks for all the info, I to had to replace my leaky water pump and was amazed how easy it was,it didn't change anything for heat but its dry now, I'll try spraying out radiator out see if that helps, thanks again
Old Mar 12, 2009 | 09:32 AM
JDH's Avatar
JDH
Also check out the fan clutch an expensive piece and prone to fail at about that age, I have a bad one and am in the process of replaceing, approx 400$.
Old Mar 12, 2009 | 10:36 AM
srountreeoo7
My truck runs at 200 all the time. That is the normal range for mine.
